A/C Heater temp control dial
+ Reply to Thread
Results 1 to 5 of 5
Thread: A/C Heater temp control dial
  1. #1
    Supporter LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002's Avatar
    Join Date
    Jan 2003
    Location
    Plymouth, MN
    Age
    72
    Posts
    2,196
    Liked
    9 times
    Images
    17
    Rep Power
    1317
    Default A/C Heater temp control dial
    Has anyone in the cold climate regions run into a problem with their temperature control dial on a 2000 Tundra. When the outdoor temp reaches below zero and the truck's been sitting outside the dial has a lot of resistance to movement. It's severe enough at 10 below zero I'm concerned the shaft will snap. If I leave it alone and wait for the cab to warm up ( dependant on it's existing setting) then with some resistance it's moveable. Between zero and forty degrees (all it's seen since I bought it) it works fine.
    Thanks, lgl002
    2003 Camry SE V6 Navigation, Sirius, Lunar Mist
    Optima 34R battery
    Turn signals are meant to indicate intent not result.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member maisano is on a distinguished road. maisano's Avatar
    Join Date
    Feb 2003
    Location
    Keller, TX
    Posts
    585
    Liked
    0 times
    Rep Power
    11
    i actually took my to the dealership because i forced mine to move. they had to do a minor adjustment. but you need to be careful and it will break and then not go all the way back.
  4. #3
    Junior Member champcaracing is on a distinguished road.
    Join Date
    Feb 2002
    Location
    Clinton twp., MI
    Age
    47
    Posts
    63
    Liked
    0 times
    Rep Power
    12
    when i had mine, i had the "cable" replaced, i had wash the engine area the night before and it froze up here. in the morning i tried to move it...forced it then it never work correct. they replaced it no charge, spray the water valve with wd-40 or other lube, also lube inside the little boot where it goes into the truck....won't hurt any???
  5. #4
    Join Date
    Jan 2003
    Location
    Plymouth, MN
    Age
    72
    Posts
    2,196
    Liked
    9 times
    Images
    17
    Rep Power
    1317
    Thread Starter
    Thumbs up Thanks
    Thanks guys for the assistance. You've given me a path to follow to resolve the problem. I had thought it might be a rotary type vacuum switch and it was the dial mechanism that was the problem. As soon as it warms up enough around here I'll try your suggestion.
    Optima 34R battery
  6. #5
    Junior Member Stooge is on a distinguished road.
    Join Date
    Feb 2002
    Location
    Baltimore, MD
    Posts
    487
    Liked
    0 times
    Rep Power
    12
    The cable has water in it and it frezzes when cold. Blow it out from the inside with compressed air and lube it with WD40 or the like. The cable points upward on the firewall where it connects to the heater TCV - anytime water gets in there and it gets cold, this is bound to happen!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
