Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 03-06-2008, 01:16 PM
Dealer : Champion Toyota Scion of Austin
2005 Toyota Tundra
Last Online: 09-18-2009 11:04 PM
brucea is on a distinguished road.
brucea's Photo Albums
Default Rust Prevention on 05 Tundra
Hi,
I'm trying to get some advice on preventing rust on my truck, especially the underbody/components and engine compartment components.
Background:
I live in Texas and kayak a lot on the Gulf Coast therefore I'm in sand and salt/mud a lot. I try to thoroughly clean the truck after every trip by spraying the entire underbody and engine compartment with fresh water and then doing an underbody pass through the mechanical car washing machine.
I still see spots of rust especially on the underbody. Just recently I took off the skid plate (to change the front diff. lube) and found that the rust was much worse under there.
Questions:
(1) Are there better ways or different things I should consider for cleaning?
(2) Are there treatments or coatings that can be applied that will reduce the susceptibility of rust?
thanks for your help
Old 03-06-2008, 01:56 PM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: Today 04:41 PM
123Gone will become famous soon enough.
123Gone's Photo Albums
Default Re: Rust Prevention on 05 Tundra
1. Clean the rust off as best you can: Use a degreaser first, then use a phosphoric acid wash (85% diluted 20:1). You may be able to buy a pre-diluted product with added degreasers. Phosphoric acid will convert rust in to a water soluble iron phosphate. Rust will blacken as it is converted. Rinse with water thoroughly when finished. Note: A gel type phosphoric wash called Navel Jelly can be found in many hardware stores.
2. Let the areas dry and then coat with a rust preventative such as POR-15: POR-15 Inc.
Old 03-07-2008, 10:49 AM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 03-09-2009 07:27 AM
Images: 5
TundraSurfBum is on a distinguished road.
TundraSurfBum's Photo Albums
Por-15
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
285 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
WADE in-Channel Visors
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
Old 03-07-2008, 11:06 AM
VIP-01's Avatar
UNLEASHED
Dealer : Quality Imports Toyota Scion
2005 Toyota Tundra
Last Online: 01-06-2009 05:04 AM
VIP-01 is on a distinguished road.
VIP-01's Photo Albums
I had my trucks undercarriage, inner fenders/wheel wells and the engine compartment thoroughly cleaned, treated then coated with a polyurithane type mixture (or something that looks like it, anyway) that formed to all the surfaces it made contact with. It's a permanent coating that seals the surface area and even made it easier to clean mud off. And it made the wheel wells and engine bay look alot better
'05 Tundra 4x4, Volant CAI, Dual 40 series Flows with X-pipe, Unichip FluxPower w/PDA, 6-in RCD suspension, 35" Dick Cepek's on DC-1 Wheels, ARE Tonneu Cover, Line-X liner, FabTech in-bed spare tire rack, two-piece polished Billet Grille, Bull Guard, stainless running boards and Custom 19-piece Neoprene interior...soon to purchase '08 Tundra 4x4
Old 04-05-2008, 09:01 AM
Dealer : Gateway Toyota - Kingston
2005 Toyota Tundra,
2008 Toyota Sienna
Last Online: 08-23-2009 01:05 PM
kas1963 is on a distinguished road.
kas1963's Photo Albums
I'm not sure if the company is in the USA but here in Ontario I've always used a company called Krown rust proofing. It has done a good job for me. Its a spray that is applied underneath as well as inside the panels. It drips out for a few days but it seems to work.
