Just wanted to start this again . What worked best for me was Dental floss. Placed it between the double sided tape and the badge and worked it a little at a time .Then removed the excess tape with my fingers.
Bill
THAT'S THE HILLBILLY WAY
2006 Limited 4x4 ,Debadged.Westin side bars,Hellwig Sway bar, Lund Deflector ,Snug-Top Expo shell .Magnaflow 14" muffler with resonator removed.
" If I knew I was going to live this long I would have taken better care of myself " "Marriage changes passion...suddenly you're in bed with a relative."
I used the dental floss and "goo gone" it worked good and left a nice scent of lemons...lol anyways, a thing piece of twine might work a little bit better and keep from getting your fingers sticky from the flavored floss
Mods
JBA Headers, Maplight mod, Rear seat angle mod, Snug-Top Bed Cover, ToFF Spray-in-liner, Unichip, 2 12" subs in the bed, Rockford Fosgate components, Rockford Fosgate Coaxials, Helwig Anti-sway bar, lowering shackles, Nifty scratches and dents all around .
I went with 20lb fishing line! That and a hair dryer and I was, uh, stylin The dental floss kept breaking. Even the fishing line broke a couple of times. Followed up with 3M adhesive remover and that was it.
I went to a body shop supply store, and picked up some adhesive remover. Then, I snuck my wife's hair dryer out into the garage. It seemed to take a LONG time, but eventually the goo softened up enough to allow me to peal 'em off with my fingers. The adhesive remover wiped off the leftover glue quick as a wink. A couple of microscopic chips in the paint, so small I haven’t even bothered with touch-up paint.
A few days later, I noticed my wife was using a new hair dryer. Afraid I’d messed up hers, I asked her, “Why a new hair dryer?”
She said, “I noticed the old one just wasn’t heating a long time ago, and finally remembered to pick up a new one.”
Moral of this tale: New hair dryers are cheap. Pick up one if you want to do this. Your wife will probably appreciate it.
__________________ Larry Lawton
Retired in Wyoming
I saw a white tundra 4x4 the other day. This truck was sweet. Lifted and clean. No badges except the SR5 by the rear door. Has any one else removed the badges and if so what do you think? Are all the emblems just "STICK ON"? My truck is silver sky metalic, I'm thinking it will look nice cleaned up a little.
Re: badges or no badges??? Who has taken em off, hmmm
Suprteck, I think your truck would look a lot better w/out the badges, gives it that clean smoothed out look. I own a sequoia and I removed all of mine. not sure on the tundras, but I believe they are all stuck on w/ adhesive.
Chris
__________________ 2001 Sequoia 2WD SR5 Mods: Rollers - 18x9 JAOS Super Ziga wrapped w/ 285/65 BFG A/Ts, Suspension: SAW 2.0 Adj. Coilovers, UCAs, Rear Coilspacers I.C.E. - Clarion H/U w/ built in monitor, DVD Player, Drop Down, Headrest Monitors, Exterior: - Stock OEM Foglights, Wings West Spoiler, Engine:TRD Drop-In Filter
mine are off to the point it look's clean and unbroken. Toyota did put to many badges on the tundra and i like the clean look .ive taken the ones off the rear door too and the look is better and to the point of a badge less truck...
also take off those side modlings off too it improves the look ask quicktoy he give me that ideal on mine to do (allready done) but make sure your 2 inch hole's under those modlings are welded shut .....later tundrav8 (fox racing tundra)
yep me too. i removed all of the badging, pin stripes and trd. only thing left is a different grill and then the only toyota association on my truck will be the stearing wheel and of course my TS plate & sticker!
__________________ 2006 Tundra Limited DC: UniChip | Ram Air Performance System | TrueFlow Sealed Air Intake | 24" Bassani X-Muffler with Quick Time Electric Cutouts | IS Rims w/ Michelin LTX A/T2 265/70R16 | SkidRow FSP | Hellwig Antisway Bar | Retrax Bed Cover | Bazooka VSE | front/rear parking sensors | power tailgate lock | debadged | tinted windows | 2x baby mod (car seat) 2005 Sienna: Purple Plazma Headlights | de-badged | 2x baby mod (car seat)
you can compare the moldings and badges on the big tundra to no moldings and badges on the small one here:
Moderators Note:
the picture link in this post has been removed as it was longer working
SATundra - Moderator
2001 SR5. WORLD'S LOWEST TUNDRA. Stock floor body drop on full tubular frame. Independant rear suspension, full air bags. Hi-Performance Designs 22" rims. Body mods: 05 Front clip, shaved; door handles, antannae, firewall, hood squirters, rear bumper, gas door, bed rail caps, tailgate handle. Paint is Godfatherracing.com colors. ScrapeN-Customs built the truck, the Collision station painted it. Texano did the airbrush work.
I have a 2001 White Limited TRD and I took off all my badging. It is ALL stuck on with adhesive, with the exception of the body moulding. I used the dental floss and goof-off method on the badgine, and a rubber gum detailer's wheel (thanks again FDJanzen!) to take off the TRD stickers on the rear fenders. I love the look, and it is SOOO much easier to wash and wax now without having to worry about those areas!
Use the dental floss and run it in back of the emblems. This will cut the adhesive away. I used fishing line because the dental floss kept breaking. Once the emblems are removed take some adhesive remover(I used 3M adhesive remover, available at auto stores) and spray it on the adhesive. Let it sit for about 30 seconds and rub off the adhesive with a towel. I also recommend washing the area before rubbing off the adhesive. Since dirt gets collected behind those emblems and sticks to the adhesive, rubbing it out may cause a lot hair line scratches if you don't wash it. Hope this helps, Mike.
I like the de-badged look also. I ended up taking the SR5's off and the Toyota Tundra emblems on the front doors. I still have TRD stickers on the bed for now. I haven't done anything with the tailgate badging yet, although I probably will at some point. Looks a little cluttered, so I'm not sure what to do. I'd like to leave something there, just not sure which ones yet. Take care, Clay
