Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 03-15-2003, 02:06 PM
Dealer : Rockingham Toyota
2005 Toyota Tacoma
Last Online: 09-16-2009 07:47 PM
NHTundra is on a distinguished road.
NHTundra's Photo Albums
Default Anyone ever installed TRD Flares on base Tundra?
I bought a set of used TRD flares not realizing there needed to be holes in the sides of the fenders to mount them. I have a base Tundra Access Cab that had no flares at all and I stupidly thought that the flares only mounted from from the inner/bottom edge of the fender.
Has anyone ever attempted to cut square holes in side the fenders to mount these flares?
Boy I feel stupid. : (
Thanks.
Old 03-15-2003, 04:11 PM
ChuckFundra's Avatar
Dealer : Cabe Toyota Scion
2002 Toyota Tundra
Last Online: 09-19-2008 02:57 PM
ChuckFundra is on a distinguished road.
ChuckFundra's Photo Albums
I may have missed something but I have the same truck that you do and there are square holes in the fender opening lip in about 3 places (I would check but it is in the shop right now)
I think all of the flares available mount to these holes.
Chuck
Mods:Hellwig anti-sway bar, clear front side marker lights, clear/red/clear rear tail lights w/chrome trim and led blinker, billit grill w/hidden badge, painted front bumper valances, 4Runner 5 spoke wheels, Leer 100xlt shell w/carpet kit, most badges removed, custom Fundra badge on rear, additional reverse lights, gauge trim painted white, custom shifter knob (on the floor), billit radiator and oil caps, comp/temp mirror, map light, charging outlet, back seat tilt, and door & ignition buzzer mods
Old 03-16-2003, 07:50 AM
2005 Toyota Tacoma
Thanks for the reply Chuck. That's what I thought when I bought the flares. Trucks with TRD flares actually have square holes cut in the side of the fenders about 2 inches from the lip. I sure would like to mount these flares, but I'm pretty leary (sp?) of attempting to cut holes in the fender.
Old 03-16-2003, 09:54 AM
2002 Toyota Tundra
Yah, that's pretty perminant.
Check with your dealer they might know some trick, or just go to the lot and check out a trd equipped truck.
Chuck
Old 04-07-2003, 09:31 PM
Dealer : Atlanta Toyota
Last Online: 01-23-2006 10:06 PM
networkguy is on a distinguished road.
Send a message via ICQ to networkguy Send a message via AIM to networkguy Send a message via Yahoo to networkguy networkguy's Photo Albums
I mounted TRD Flares to my truck as well and didn't bother with cutting the holes. The flares will mount on just fine with the bolts inside the wheel well. They fit quite flush and i havent had a problem for the 2 years i've had them on.
Old 04-07-2003, 09:59 PM
2005 Toyota Tacoma
Thanks NetworkGuy. I was just about to give up. The local dealer wanted $250 just for the install. I'll give it a shot without drilling the holes.
Old 04-09-2003, 06:41 PM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
TRDKEAU's Photo Albums
you might want to slap some epoxy mix adhesive as well as the 3m tape that came with it. It softens up but keeps a tight grip. Just so you dont leave a flare out on the freeway one day. I had SR5 flares and replaced them with IS flares
Old 04-17-2003, 03:04 PM
Steelshot's Avatar
Dealer : Toyota of Santa Barbara
2002 Toyota Tundra,
2006 Toyota Tacoma 2WD Grocery Getter
Last Online: 09-05-2009 02:50 PM
Steelshot is on a distinguished road.
Steelshot's Photo Albums
Since you bought the flares used you'll need to get some 3M two sided tape. If you're a full member, you can go to the instructions on how to install the Ivan Stewart body kit. Information on this tape is in there. I would think that a combination of the tape and the fasteners along the wheel well lip would hold the flares, though it is interesting that Toyota saw fit to punch the square holes. They must feel the extra security is worth the extra cost.
Ivan Stewart Body Kit; IS Wheels; Clear Corners w/ silverstar 3157A bulbs; Snug Top SuperSport cap; Marathon Super Hides seat covers in Shadow Grass; Husky floor liners; Toyota self-dimming rear-view mirror w/ temp & compass; Yakima Track Racks; debadged; Colgan front mask (only when going off-road); Cornfed 2 inch lift; Fabtech add-a-leaf; Total Chaos 1 inch differential drop kit; silver/blue TRD Offroad decal from Street Graphics.net; Line-X spray-in liner; 2005 tail lights; tailgate seal; Challenger Step Bars; Hellwig sway bar w/ Frontrange disconnects; SolidWiring Technology FOG603 foglamp mod & DRL601 switchable DRLs; battery manager; Prodigy brake controller.
Old 04-17-2003, 07:58 PM
Dealer : Fremont Toyota
2002 Toyota Tundra
Last Online: Yesterday 01:59 PM
Triple BB is on a distinguished road.
Triple BB's Photo Albums
Just get some small self tapping sheet metal screws. Have someone hold the flare in place and set the screw in place. Plastic washers are beneficial. I've had Bushwacker flares on four different vehicles in recent years and have never had a problem with rusting. In fact, I think that was about the only way they mounted their flares for years. If you think rust protection is necessary, apply some Aqua Seal or other urethane adhesive to each screw before you set them. Double sided tape ain't the answer if you'll be doing any off roading. Eventually you'll hang a flare on some sage brush or a tree limb and the flare won't be there when you get home.
