This is a discussion thread titled "Sprayed rustproofing on rear axle", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-17-2008, 07:22 PM
seadragon's Avatar
Dealer : Milton Toyota
2006 Toyota RAV4 Limited,
2007 Toyota Tundra 5.7L DC 4x4 SR5 TRD
seadragon's Photo Albums
Last Online: Yesterday 07:35 PM
seadragon is on a distinguished road.
Default Sprayed rustproofing on rear axle
Well, after my first year with my Tundra, there is some rust on the rear axle. Particularly the rear diff housing, axle and springs. So I went out and bought some spray rustproofing and it really does a good job of coating everything. Its like a clear gel that coats the metal. It's supposed to dissolve rust and protect the metal. We'll see. I plan on spraying under the rockers and some of the front too.
Here are some pics after spraying the axle. I didn't think to take "before" pics, but you can clearly see the rust I have after 1 winter. Hopefully this stuff will help.
2007 Tundra 4x4 5.7L SR5 TRD BLK
Old 06-18-2008, 11:29 AM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
123Gone's Photo Albums
Last Online: Yesterday 04:59 PM
123Gone is on a distinguished road.
Default Re: Sprayed rustproofing on rear axle
Hmmm, interesting.
The product is a solvent and phosphoric acid. Phosphoric acid (PA) is a very common rust converter. PA converts rust to iron phosphate which is non-corroding. Iron phosphate is black. So, if you see the rust turning black, it's working. The only thing I would be concerned about is that typically, the phosphoric acid needs to be washed off. Otherwise, it could etch a surface.
Report back as to it's progress, I'm interested. Thanks
Old 06-18-2008, 08:41 PM
cleanb13's Avatar
Dealer : Boch Toyota South
cleanb13's Photo Albums
Last Online: Yesterday 03:08 PM
cleanb13 is on a distinguished road.
I can't understand why there would be that much rust on a 2007. I bought some Rustoleum rust spray in flat black and did what I could reach on my back. I'll put it on a lift a work soon and do everything over again to make sure I didn't miss any spots. The Rustoleum spray is supposed to stop rust for two years. We'll see.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 Revos on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Aero 2525 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate, EBC "green" brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Wheeler's polyurathane front swaybar bushing kit,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Silverstar fog light bulbs, , Viair 300P air compressor
Wish list: Line X'd front and rear bumper, rock sliders
Old 06-18-2008, 08:44 PM
cleanb13's Avatar
I tjust occured too me, does that stuff dry or does it saty tacky? If it stays tacky all the dirt, dust, and sand will stick to the housing and defeat the purpose.
Old 06-21-2008, 08:29 AM
KLINDSEY's Avatar
Dealer : Beechmont Toyota
KLINDSEY's Photo Albums
Last Online: 10-11-2008 07:22 AM
KLINDSEY is on a distinguished road.
Try this product it works wonders can be had from the this link or Amazom, and on ebay also. I have a friend who put this on the under side of his lawn mower deck 2 years no signs of wear chipps or rust, hard as nails and stops rust. No cleaning required spray areas with the prep and dry then paint till your done and enjoy. It really works.
Kevin
http://www.stoprust.net/?gclid=CK3w7...FRUdsgod7XLPjw
KLindsey
Old 06-21-2008, 08:57 AM
seadragon's Avatar
It stayed tacky for a day or so, but I've since pressure washed it and now it looks dry. The rust is still visible, but has turned darker in color. I'll take another couple of pics later today so you can see the difference.
Old 06-21-2008, 01:48 PM
123Gone's Avatar
2005 Toyota Tundra
I thought I would throw in that an alternative product would be POR-15 with perhaps POR-15 BlackCoat as a topcoat.
Old 06-21-2008, 02:38 PM
Burger Steak & Eggs's Photo Albums
Last Online: Today 02:56 AM
Burger Steak & Eggs is on a distinguished road.
Anything that comes from a rattle can will probably be gone in a year or two. It is a tough environment under there. To really go full out on the housing, I would remove it and sandblast, taking care to mask areas near seals and breathers etc. Then zinc chromate metal primer/sealer, followed by some polyurethane "plastic" paint. There are variants of this with teflon added, specifically meant to withstand areas of high abrasion, such as fender wells etc. Removing the diff is not an easy task, but perhaps some wire brush / chemical cleaning could substitute when the truck is new and still clean.
Old 06-23-2008, 06:45 PM
seadragon's Avatar
Okay, so I just took these pics tonight. As you can see, the axle is not as wet as it was after I sprayed it. Still, it's not pretty.
Old 06-24-2008, 09:28 AM
123Gone's Avatar
2005 Toyota Tundra
I think it should have worked by now. It does not APPEAR that the rust has been converted.
Here's a link to POR-15. POR-15 Rust Inhibitor first with a coating of BlackCote (see "Single Part Topcoats") might be a better solution.
POR-15 Inc.
Old 09-22-2008, 01:55 PM
Dealer : Toyota of Morristown
2003 Toyota Tundra
crainholio's Photo Albums
Last Online: 10-05-2008 08:47 PM
crainholio is on a distinguished road.
I've gotten great results by starting with POR's "Metal Ready" liquid to prep the surface whether rusty or not. It neutralizes the rust, and leaves a zinc phosphate finish that the paint will adhere to.
I just did my frame rails and weld joints with this prep, and Krylon rust-preventing semi flat black spray paint. We'll see how long it lasts, and if it doesn't hold up I'll use POR-15 paint next time.
