Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
  #31 (permalink)
Old 10-16-2008, 10:50 PM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: 11-19-2009 10:28 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Default Re: 2005 Tundra DC HID Retrofit Progress
Projectors and shrouds. I cut off all non-essential mounts on the projectors. (the pictures show the stock projectors, not trimmed)
I can use the stock bulb seal!
  #32 (permalink)
Old 10-18-2008, 04:56 PM
Images: 11
Test fit passenger side. Tonight I will test beam pattern again, with both new headlights installed. One of the projectors I am going to try to exchange at the place I bought them. (They gave me two with different cutoff shields).
I'm thinking of removing the light bar once I have the HID's installed. I think with the projectors there are too many round lights on the front, I'll see once it's all done.
  #33 (permalink)
Old 10-18-2008, 10:28 PM
tinik's Avatar
Travel & camping is 2 much fun
Dealer : Cramer Toyota Scion of Venice
2006 Toyota Sequoia,
2001 Toyota Tundra Supercharged
Images: 51
tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One.
tinik's Photo Albums
I think you should keep your light bar...
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
  #34 (permalink)
Old 10-19-2008, 12:47 AM
kaleo's Avatar
I'm just here for the food!
Dealer : Servco Auto Center
2005 Toyota Tundra
Last Online: Today 05:57 AM
Images: 1
kaleo will become famous soon enough.
Send a message via AIM to kaleo kaleo's Photo Albums
Dude, just keep the lightbar....
the more lights the better!
Your project is coming along great! Keep it up
2005 Tundra Double Cab 4x2 SR5 in Spectra Blue Mica
Modifications:
Exterior: A little bit of this
Interior:A little bit of that
Performance:A few knick-knacks in between
  #35 (permalink)
Old 10-19-2008, 08:09 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
x 3 about keeping the bar and lights. I was about to run two Hella FF1000 Xenons and 2 FF1000 halogens but it blocked access to the hood release
And yes the project is looking great. That's awesome being able to keep the back housing/seal intact
  #36 (permalink)
Old 10-19-2008, 08:18 PM
Images: 11
Busy this week so I probably won't be working on it that much. I got both projectors installed, now I just have to tweak the projector alignment. The driver side is a tilted a little, so I need to fix that. I'm glad I could use the stock bulb seal, I did have to trim it a bit though. Just because the size of an H4 connector is a bit smaller than the ignitor connector. I have clear lenses coming in tomorrow. This will give a sharper cutoff and more color in the cutoff.
I also got a chance to really test my harness. Everything works as expected, high beams don't deactivate the ballasts, and the high beam indicator lamp works as it should.
Here you can see the difference between the two cutoffs. The yellow cutoff is a "pre recall" projector.
  #37 (permalink)
Old 10-20-2008, 11:51 AM
Images: 11
The replacement projector shield should be here later this week, so both projectors will have the same cutoff.
This is where I bought my projectors and lenses: The Retrofit Source (U.S.) -- Welcome to The Retrofit Source Store - The Retrofit Source
They were very helpful and fixed my shield issue quickly
  #38 (permalink)
Old 10-20-2008, 09:27 PM
Images: 11
Worked on the beam color and cutoff a little bit tonight. I installed the clear lenses onto both projectors, I'm shocked at the difference it made! Now I'm second guessing myself. I asked the place I bought these to swap out my shield that is pre recall to a post recall shield. Now after I install the clear lense, it looks like the pre recall shield produces the best cutoff. I'll see if I can send them back the replacement shield which should be here tomorrow, for a pre recall shield. Hey I'll pay for the shipping, I just want that nice cutoff
Before clear lenses, pre-recall shield left, post-recall shield right
BTW, in the below pictures, the projectors are not mounted on the truck, that's why the angle is so steep
"Pre recall" shield with clear lense
"Post recall" shield with clear lense, see how much worse the cutoff is? It's a whole lot more fuzzier.
  #39 (permalink)
Old 10-20-2008, 11:39 PM
tinik's Avatar
Images: 51
very nice... i never thought that clear lense would make such a big difference
  #40 (permalink)
Old 10-21-2008, 03:25 AM
kaleo's Avatar
2005 Toyota Tundra
Images: 1
just a nice little tidbit of info for you folks...if you have the fx35 projectors with the factory clear lens, you will see a nice color cutoff and all that. Switch that out with the RS FX/G clear lens and you will notice another change in sharpness and color cutoff.
Reason being is that RS has their lenses optically grounded a bit different then the factory CL.
Your projector output and color band looks just like mines! Though I put my 85122+ aside for when I really need it and am currently running a MaxVision 6k D2C. This bulb dimmed output a little, but supplemented the color band especially in the blue and violet colors.
But spotlights on you...keep the pics coming! It's looking awesome
Modifications:
  #41 (permalink)
Old 10-22-2008, 01:14 AM
Images: 11
Ok, The drivers side is finished!! Matt at retrofitsource said he would exchange the shield again (he has been a great help throughout the project!) So tomorrow I will return my shield and get a "pre-recall" shield later this week.
So here are the finished pictures for the drivers side. I might change the bulbs out to real philips D2S bulbs vs the ebay bulbs to see if there is a difference in light output. These really light up the road (up to 5 lanes). They won't overpower other vehicle lights in those lanes, but you can still see the cutoff. I drove a while tonight with both headlights in and did not get flashed at all, passed by a few police cruisers and they didn't budge
No light leaking!
  #42 (permalink)
Old 10-22-2008, 05:59 PM
Images: 11
Picture from behind on both sides.
  #43 (permalink)
Old 10-22-2008, 06:03 PM
Images: 11
If you look really hard from the side you can see my mount, it is not intrusive at all. That big streak on the top right hand side is a bug Second picture shows the reflection from behind the projector. I covered the back of the projector with aluminum tape to block out the light and to create a shiny surface.
  #44 (permalink)
Old 10-22-2008, 09:54 PM
Eddie's Avatar
Moderator
2000 Toyota Tundra,
Images: 32
  #45 (permalink)
Old 10-23-2008, 04:28 AM
1998 Toyota Corolla
Last Online: 12-09-2008 11:23 PM
boredstudent3 is on a distinguished road.
boredstudent3's Photo Albums
hey dibble,
very nice post man, it really helped me grasp an understanding of the work needed to do a retrofit.
i have a few questions (for you or anyone else involved in this forum) that I hope you can help me w/:
1. did u have to cutout a larger hole in the reflector to push the projector thru? (i.e. was the stock bulb hole large enough? i personally don't think so)
2. that is a FX 35 or 45 projector? are they the same size? i personally own a toyota myself but not tundra (corolla instead, family car) so i don't think there is much room to insert a larger projector.
3. did u only use 3 longer mounting screws to hold the projector in place? I believe they are just screwed into the reflector correct?
4. how did u wire up the solenoid on the projector? i took a look at the wiring dirgram and i couldn't figure it out. heh I assume that it will need a signal from the steering wheel lever (when you pull back on the switch) and a ground?
5. what parts of the projector did u trim off? i didn't get to see a pic of that.
6. i noticed that you were able to use the OEM black dust/end cap and I guess i should plan my cutting and mounting so that I don't have to modify mine either. lol, good thing to keep in mind. But then i noticed that you have to put aluminum tape around the end of the projector, so that means that it goes thru the black end cap? (i.e. you have to cut out a larger hole in the end cap for the rest of the projector to fit?)
7. did u use anything to seal up the back of the reflector and what did you use to seal up the clear lens with the housing, silicone or epoxy?
8. in the OEM headlight housing i know that the bulb is adjusted by 2 screws. how do you adjust the D2S bulb in the projector? are there 2 screws also? I'm curious b/c retrofitting just mounts the projector onto the reflector and is not connected in any way besides the 3 mounting screws...heh, there must be a way to adjust the bulb positioning...
wow, i know that's alot of questions from one post, heh...i apologize for that but i'm really interested in doing a retrofit and i don't think that i should be paying someone else a few hundred's to do this for me. besides, it'll be a learning opportunity for me as well. thanks for your time bro, much appreciated.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/interior-and-exterior/146731-2005-tundra-dc-hid-retrofit-progress/
Posted By For Type Date
2005 Toyota Tundra HID Retrofit Progress - Toyota Forums :: Toyota Nation This thread Refback 10-22-2008 11:36 AM
