This is a discussion thread titled "Dash squeaking", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Truck is 6 months old and absolutely no problems. I live in Birmingham, Al. It gets in the 20's and occasionally the 10's. Whenever it is around 25 degress or below the dash "squeaks" terribly. It appears to be coming from near the windshield. It only happens when the temp drops and warming truck through defroster seems to cure it. Not being picky as it will really squeak. Wondered if anyone else had this problem? OTher than that the truck is great.
I have had my 2002 Tundra since Nov. And here in Alaska I notice the same problem. The Dash starts to squek any where from 20 to -20 Degrees, One of the other guys on here had the same problem, and the dealer fixed it for him. Can't remember who he was be for the System Crash here though. I just ignore it. I drove mine up to Fairbanks a couple of weeks ago and noticed at -25 Degrees it stopped......Weird
Recommend getting some Frostking 1/2" caulk backing material (round foam rubber) from Home Depot, Lowes, or Hardware store. Place it between the dash and windshield (inside the gap). You won't be able to see it and it cures this squeak.
quote: Originally posted by wschmpn:
what about anyone's dash rattling like near the rear of it at the windshield. sounds like something has just barely come loose i can bump the front of the dash with my hand and it will stop for a while That's the same squeak/rattle everyone's talking about. Follow Redmonds recommendation with the caulk backing material and it WILL stop. I did this about a month ago and haven't heard a squeak since. Its cheap, easy and it works great!
I have that 'same dash squeak' everyone is talking about. But there's another squeak that I also have.
This one is speed (of wind) dependant, not a function of going over bumps. It's as if the windshield might be loose enough to be rubbing against the molding? In another thread, someone recommended spraying the molding with silicone, I'll give that a shot
I thought it might also be a loose antenna, but it doesn't seem all that loose. For those that had the antenna TSB performed, what did it sound like before the operation? How loose was it?
RedmondRecommend getting some Frostking 1/2" caulk backing material (round foam rubber) from Home Depot, Lowes, or Hardware store. Place it between the dash and windshield (inside the gap). You won't be able to see it and it cures this squeak Testimonial to "Redmonds Dash Squeak Remedy I bought the FrostKing 1/2" round polyfoam caulking for $2.86 at Home Depot today Installed all along edge of dash from driver to passenger side. Works great...no more squeaks!!
YES! This worked for me too! I was getting a "creaking" sound going over bumps and sometimes just changing lanes over the "bots" dots. Took some looking at Lowes to find it. It was back in the weather striping section, also known as Backer rod. Guess you have to be in the biz to know that one! This is a 1/2" thick, circular foam piece that I wedged into the space between the dash and windshield with the eraser end of a pencil. Cost me all of $2.50 and works to perfection
Cheapest mod I have ever done.
Herbicidal
My daily driver - 2008 Yaris sedan 'S'. Tinted windows in the rear, TRD anti-sway bar for the rear, 17" rims - Samurai SC02 Hyper Black. TRD lowering springs.
My favorite ride - a 2001 SR5 4x4. With - RCD 6" lift, JBA Titanium coated headers, JBA y-pipe, Unichip PnP, ARB rd-129 air locker (rear), Camburg UCA's, custom front Sway-A-Way coilovers, custom Sway-A-Way's with remote reservoirs and billet mounts for the hind-quarters, PolyPerformance limit straps with adjustable clevis's - mounts welded up by AJ at BentUp.com, Stubbs Welding rock sliders and custom front skid plate, 315/75/16 Toyo Open Country M/T's, on all 4 corners wrapped around 16x8 MB Motoring Blitz rims, cryo'd 4.88's set up by Inchworm Gear, Trenz billet grill upper, T-Rex billet grill lower, on board VI-AIR aircompressor and 3 gallon air tank from Wheelers Off-Road, Inc, AutoMeter A-pillar pod with transmission temp gauge (sending unit in the tranny pan), Long Tru-Cool LPD tranny cooler, 10" Flex-a-Lite tranny cooler fan w/thermostat, TRD billet oil filler cap, TRD air filter, TRD dual exhaust, and TRD add-a-leaf rear springs. Superlift TruSpeed Speedometer Recalibrator. Warn Trans4mer Grill Guard, brush guard and 9.5ti winch w/cover. Budbuilt traction bar. Wheelers Off Road Centric performance brake rotors: cross-drilled and slotted. Staun tyre deflators set for 13 psi. Our home away from home, 2004 Outback 26RS travel trailer with 15" MB Motoring Blitz rims to match the Tundra.
Sounds like the next mod i'm going to do...tonight actually! My dash drives me crazy with squeaks/creaks. Can't wait to try the remedy everyone is talking about!
BFG A/T 285.75.16 / MT Classic II's / Fabtech Coilovers / TRD Add-a-Leafs / SkidRow skidplate / Snug Lid / Grey Line-X / Color-keyed front & rear bumpers / Hella Supertones / Husky floor liners / Amsoil bumper-to-bumper / K&N drop-in / Super Magnet oil drainplug / TRD radiator cap / 55w Aux reverse lights / DRL's disabled / Fog light mod / Map light mod / Power outlet mod / Back seat angle mod / Visor labels removed / TS sticker!
Well all I have an appointment with the Dealer on Monday morning to get this creak taken care of. I have just read all the suggestions on here and am on my way to Home Depot to get some Frost King 1/2" caulk backing and give it a try. My creak is coming from the center of the dash, I thought it was the defrost vents squeaking, but probably not. Will let ya all know if it works for me too. Thanks! This is driving me absolutely crazy too!!!!
I've had that annoying dash squeak all winter too. I brought it to my dealership and the first time they seemed to take some of the squeak out but not all of it. I then took it back to them and they had one of their techs work on it for 6.5 hours. They said that he took the dash apart and put foam and reseeded everything including the wiring. Well, whatever he did, he took care of it. It has been anywhere from 15-40 degrees the last few days in Michigan and I have tried to reproduce the squeak and cannot . I was about to do the frostking foam solution but I fear that it wouldn't be a permanent solution. Needless to say, I hope that the dealership's way is a permanent solution but only time will tell.
OK all it sure looks like, at this point, that you were right on. I went to Home Depot and purchased the 1/2" caulk backing, installed in between my windshield and dash the full length of the dash and the crack sound is gone. Time will be the test, but it looks good at this time. Thanks
I installed the same FrostKing caulk backing that Redmond recommended to get rid of my squeaking dash. It works great! I even went out on the trails this past weekend and not a single sound! Although, I couldn't hear my dash squeaking/cracking even if I tried because my driver side doors sounded like they were going to fall off they were rattling so much!!! That's my next trip to the dealer...the saga continues!
