Originally Posted by BENNETT_79
if its the same as my 08 DC,to remove the lower glove box,open it and pull the little shock off and then the whole thing snaps off at the bottom hinge.
Finally figured it out today....
1. Pull outward on the shock and disconnect it from the lower part of the glovebox.
2. Squeeze in on each inner side of the glovebox until the stops clear their holes. HINT: The right side is much harder than the left.
3. Gently lower the glove box until it almost hangs vertically and pull it towards you to unsnap the hinge.
4. If all else fails - Page 398 of the owners manual.....
