Re: Door/window Belt molding removal
Well, I suppose I'll answer my own question. The inside door panels had to come off and the 3 nuts for the side mirror assemblies as well. Once that's done, the belt moldings are held in by plastic clips. Not a bad job, took about 30minutes a side. They cannot be replaced w/o taking the door panel off, due to the way the mirror is mounted on top of it.
'01 tundra TRD SR5 4x4 access cab, rear Helwig sway bar, front poly end-links, temp/compass mirror, '05 tail lights, JL audio stealthbox and amp, 6x9 Sony rear spkrs, TO-25 door tweeters, new '03 TRD coilovers w/daytech 3/4" poly spacer, rear HD-Bilsteins, all weather mats, rear seat mod, Draw-Tite bugshield. Soon to install: TRD lim-slip
