Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 03-02-2009, 03:24 PM
Last Online: 11-22-2009 05:26 AM
father of 3 is on a distinguished road.
father of 3's Photo Albums
Default Respraying over Previous Line-X or Rhino install?
hi,
I thought about sending 123Gone a private message, but thought his answer or someone else's might be of use to others.
My question: What is the recommended procedure, if there is one, for respraying or spraying over a previous version of a Line-X or Rhino install?
Are there any special surface preparations that the owner should perform?
Should a Rhino only be installed over a Rhino and Line-X over Line-X?
Is respraying a recipe for disaster down the road?
Thanks.
Old 03-02-2009, 06:52 PM
616269799's Avatar
Dealer : Toyota of Muskogee
2006 Toyota RAV4,
2005 Toyota Camry
Last Online: 10-31-2009 08:09 AM
616269799 is on a distinguished road.
616269799's Photo Albums
Default Re: Respraying over Previous Line-X or Rhino install?
Definitely PM 123 Gone.
Out of curiousity, why would you want to do this? Line-X has a lifetime warranty throughout the US and I believe that Rhino is at minimum warranteed by the original installer.
Win or Lose, but Finish the Game
Old 03-02-2009, 08:43 PM
I'm actually actively trying to find a reputable Line-X dealer - mostly Rhino around me. But, my friend who is the 3rd owner of a Ford diesel truck wants his liner repaired. He's not even sure of the original liner.
Old 03-02-2009, 09:17 PM
scottnmos's Avatar
E PLURIBUS UNUM
Dealer : Nye Frontier Toyota/Scion
2001 Toyota Tacoma Xtra Cab....SOLD,
2008 Toyota Tundra 5.7 4x4 SR5 Crew Max,
2004 Toyota Tundra 4.7 4x4 DC SR5-Sold,
1993 Toyota 4Runner SR5 Wheelin' Machine
Last Online: Today 07:17 PM
scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor.
scottnmos's Photo Albums
I am pretty sure that if it is Line-X they'll repair/replace it for free. If not I am sure that the entire bedliner would have to be removed so that the new one would adhere properly.
Old 03-04-2009, 01:39 PM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: Today 02:23 PM
123Gone will become famous soon enough.
123Gone's Photo Albums
I thought I would go ahead and chime in.
LINE-X has a patented process (which won a SEMA award in 2008) called ReNew. ReNew can be used on ANY brand of spray-on bedliner. The process includes a new textured layer and the use of LINE-X Xtra, so the bedliner will not fade or lose it's gloss.
Prior to ReNew, LINE-X dealers cleaned the bedliner and then applied a special primer prior to the application of the new bedliner product. This also works, but using the primer was not always convenient (for reasons I won't go into, it's a long story).
I can tell you that just cleaning the bedliner and then spraying a new coat will NOT work, no matter what the brand. It will eventually fail by delamination due to poor or no adhesion of the layers.
A local body shop took a truck that needed just one bed side sprayed to a Toff dealer in my area (who is now closed). The rest of the truck bed had LINE-X. The Toff dealer spray the side as well as the rest of the bed so that the entire bed looked the same. Well, the respray failed. The body shop then brought it to us. We had to strip the entire bedliner out and start all over again. Here's some pics of the delamination:
http://img.photobucket.com/albums/v4...TRiggpeel1.jpg
http://img.photobucket.com/albums/v4...TRiggpeel3.jpg
Bubble:
http://img.photobucket.com/albums/v4...nds/TRigg1.jpg
Old 03-05-2009, 08:55 AM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: Today 08:09 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
I had this issue after someone hit me last year. The Rhino installer for the PO did not do a good installation and made the bed floor REALLY thick. Spraying over that would have created problems near the tailgate and several other areas. I ended up removing the entire bed liner myself, big job, but well worth it. The new linex liner looks awesome compared to the rhino.
Removing Rhino Liner
