I replaced all my interior lights with LED from V-LEDS. After two weeks one of the high dollar ($10.00) LED bulbs quit . Only two of the 8 LEDS are working on the bulb. I sent V-LEDS an e-mail asking for a replacement so I will post here the results of the support. What kind of life expectancy should we get out of these bulbs?
LEDs are usually good for 10000+ hours as long as they are not driven very hard. Some manufacturers run their LEDs very hard and that really cuts down the life expectancy.
We will absolutely take care of the bulb, that is not a problem. If I have not responded to your email already, I will look for it when I get back in the office and send a detailed reply immediately.
There is a thread in the forum that talks about changing your interior lights to LED. I did the upgrade but one of the lights failed. I contacted the vendor (V-LEDS.COM) and told them of my problem. I was sent an email on the 9th of this month and told I would get a replacement but NEVER GOT IT. Has anyone had a LED upgrade fail and if so did the vendor replace it???
no problems here,bought mine off e-bay.they are the 6 led cluster and they work good!!!!! they say that you can put them in backwards.try reversing the bulb first.
make sure that the lights are in the socket the right way..try flipping them in the socket. when i installed mine, some worked, some didnt.
__________________ 2000 Toyota Tundra A/C- 4.7
-Magnaflow dual exhaust -K&N cold air intake
-Scangauge II -"Line of Fire"
-15% tint all around -Tail light tint
-10 inch JL sub and 1000 watt amp -Drop Tint -Future mods
-Spidertrax
-Headers
-Lift
-Tires
I had one that was bad as well(flank style)...
But I had forgot to order two others, so I just bought another to replace the broken one, with that order.
At the cost of shipping, I just figured to just not deal with it, and buy a replacment.
I had this issue the other day. I ordered 8 leds (4 sets) and one light was bad. I emailed V-leds on a Friday, and by the following Tuesday I had a replacement.
2008 SR5 DC 4WD 5.7L TRD Radiant Red/Black (HM,EC,EJ,OF,RL,V5,R9,CT,LineX)
CBTMA Member
TRD Sway Bar, TRD CAI, TRD Dual Exhaust, Billet Grille, CF Dash Kit, Westin Platinum 4" Oval Nerfs, Low Range Off-Road 3/1 Lift, Rancho RS9000XL's - rear, Wet Okole Seat Covers - Fr&Rr, Toyo Open Country A/T's - 285/75/18 (35's), ProComp 6098s 18x8.5 +19, Hypertech Speedo Calibrator, Lund Genesis Tri-fold Tonneau, OE BackUp Camera, OE Fender Flares, VLeds Interior, Kenwood DNX8120 w/HD Radio and Rear Monitor
VLEDs has been good about this so far. If you don't get a response soon, contact them again!!
07' SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
AMP bed step
DIY underseat storage
Weathertech Floor Liners
Weathertech Vent Visors CBTMA member
