If I have a 1/2 torque wrench and use a 1/2 inch to 3/8" adapter (all my existing sockets are 3/8"), will the torque limits still be accurate?
The adaptor won't change the accuracy of the wrench. Just don't take on more than the 3/8' drive socket can take.
Larry
Some people should not be allowed access to tools without books!!!
I agree with Larry. I've sheered off one 3/8" adapter doing just that. Bummer.
One thing that will change the torque specs is using long extensions. For instance, a 24" extension will not give you an accurate torque measurement. That may also depend on the quality of the extension.
