08-04-2009, 09:00 AM
Assistant Administrator
Last Online: Yesterday 07:58 PM
10
Not sure what these things are called....
...but maybe you've heard of them.
What you do is, you drill a hole in the frame of your truck, or other thick piece of metal. You then hammer this plug-like thing into the hole. The plug is bored and threaded through the center. This allows you to insert a bolt into the hole without having to tap the hole or weld a nut onto it.
Anyone know what I am talking about, and where can I get them?
Salty Dog
You've been..... TUNDRASTRUCK!
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor , Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog__________________________________________________
08-04-2009, 09:19 AM
Last Online: 09-08-2009 11:41 AM
0
Re: Not sure what these things are called....
I believe it's called a bung, or it would be in the case of what I"m thinking. It could also be called a sleeve I guess. I'm sure everyones got a different name for it.
What are you trying to do? What's it needed for?
08-04-2009, 09:31 AM
10
Originally Posted by
Wiskey_33
No, it's got a specific name. I saw them once in a truck magazine.
You know those "expansion bolts" you can buy at Home Depot that you can use to hang things like curtain rods on drywall? You drill a hole, then insert a plastic plug that holds a screw? These things kind of work on the same principle.
I want to bolt a bracket onto the frame of my truck.
Salty Dog
08-04-2009, 11:31 AM
Last Online: 11-19-2009 12:22 AM
2
Google search for "Heli-coil", "Rivet nut", "Anchor nut", and "Threaded Anchor Nut". One of those is bound to be what you're looking for.
08-04-2009, 11:51 AM
10
verrot
Yep. This is them here:
Threaded Inserts - Jay-cee Sales & Rivet Inc.
Now, if I can just figure out where to buy them locally.....
Salty Dog
08-04-2009, 05:12 PM
The emblem & panel guy
Last Online: Today 01:38 AM
4
Nutsert is another name
2008 Tundra 5.7L RCSB
Custom Switch panels and Emblems for your tundra. PM for details
READ IT, LEARN IT, STAND FOR IT
http://www.usconstitution.net
Si vis pacem, para bellum
08-04-2009, 05:17 PM
Last Online: Yesterday 05:01 PM
3
Salty_Dog
Check on Harbor Fright website or if there is a store locally they have a kit with inserts and installation tool. I use these inserts often.
Paul
07 Tundra, 4X4, slate metallic, 5.7 engine, TRD duals, reg. cab, standard bed (6.5 length), Steelcraft stainless step bars, Lund bug shield, Carriage Works billet grill insert, Weathertech in-channel vent visors, Scangauge II.
08-04-2009, 05:52 PM
2005 Toyota Tundra AC 4.7L 4WD, 2004 Toyota RAV4 Sport 2.4L 2WD
Last Online: Yesterday 09:35 AM
10
Here are some pics Tim:
Here's how they went in: 1/2" hole + 8mm (8x1.25) nutsert = threaded hole in 1/16" sheet - Photo Gallery
I've used them on multiple projects with great success. My N-Fab bars are held on with nutserts. Can buy them at Grainger, Harbor Freight, NorthernTool, McMaster-Carr, Fastenal, most any hardware/fastener company.
McMaster is the best, outstanding parts selection with pictures and diagrams and shipping is pretty cheap with next day being about $6 for low weight items.
My Truck: 2005 Tundra , 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP. Suspension & Tires: 285/75-16 BFG T/A'ko , Fabtech Coils, 1.5" Wheeler's blocks , Toytec Diff Drop , 1.25" Spidertrax [front] , 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links , Wheeler's Anti-Sway Kit , Hellwig 7700 Swaybar , Timbren Rear SES
Electrical: URD MAF Sensor Calibrator , Superlift Truspeed Speed Sensor Re-Calibrator , ScangaugeII , Full LED Conversion
Stereo: Alpine CDA-9886 , Alpine & Phoenix Gold amps, Q-Logic box w/RF subs , eDead
Cosmetic: Line-X Bedliner , Custom N-Fab Steps , Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve , Debadged (partially ), Bell Truck Trunk, Access Vanish Tonneau
B e an organ & tissue donor, register at Donate Life
08-05-2009, 03:04 PM
Last Online: 11-20-2009 10:34 PM
9
Also try Grainger and Fastenal.
08-05-2009, 03:40 PM
E PLURIBUS UNUM
Dealer :
Nye Frontier Toyota/Scion
2001 Toyota Tacoma Xtra Cab....SOLD,
2008 Toyota Tundra 5.7 4x4 SR5 Crew Max,
2004 Toyota Tundra 4.7 4x4 DC SR5-Sold,
1993 Toyota 4Runner SR5 Wheelin' Machine
Last Online: Today 01:03 AM
20
I have used the harbor freight one with much success.... it was pretty cheap, but the tool was on backorder for a while.....
LinkBacks (? )
LinkBack to this Thread: http://www.tundrasolutions.com/forums/interior-and-exterior/170607-not-sure-what-these-things-called/
Posted By
For
Type
Date
Bored Dog Solutions Links
This thread
Refback
08-06-2009 03:12 PM
Linear Mode
