Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 08-30-2009, 08:15 PM
Donda's Avatar
Dealer : Fred Haas Toyota Country
2010 Toyota Rav4,
2003 Toyota Tundra Access Cab,
- Other - 1982 Toyota Mini 4x4
Last Online: Yesterday 07:55 PM
Images: 1
Donda will become famous soon enough.
Donda's Photo Albums
Default Arm Rest
The front driver side arm rest on my 2003 AC (bucket seat) drops down past where the pin is that is supposed to stop it. The pin is not worn but the arm rest itself is. Has anyone run into this and if so what fix did you use? Was thinking of drilling and tapping a hole and run a socket head cap screw in to act as a stop. I switched the left seat rest to the right and the right seat rest to the left. This worked because it was resting on the other end of the slot in the arm rest, but looked kinda goofy.
2003 Tundra, AC
Old 10-07-2009, 06:07 PM
Greggcellent's Avatar
Dealer : Germain Toyota of Columbus
2004 Toyota Sequoia Ltd ,White/Charcoal
Last Online: 11-21-2009 12:15 PM
Greggcellent is on a distinguished road.
Greggcellent's Photo Albums
Default Re: Arm Rest
I tore mine apart ,,,very easy unzip cover and removed the pivot bolt . I didn't like how far down my armrest went down . I wanted it to rest higher . I took a nylon threaded nut the was the same diameter of the stop and just screwed it on there . It fitted tight and raised the stop position as to where my arm rest perfectly while holding the steering wheel . And I can get to the seatbelt fastening without having to raise the armrest . I took a dremel tool and honed out the armrest side of the stop as to let the armrest go all the way up to its normal position .
04 Sequoia Ltd. Natural White / Charcoal , Pioneer Head Unit , Dome Lgt. Mod , Footwell Lgt. Mod , Armrest Mod ,
