Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 10-29-2009, 09:47 AM
Dealer : Basil Toyota
Last Online: 11-19-2009 01:58 PM
MarkJ is on a distinguished road.
MarkJ's Photo Albums
Default Seat Heater Wiring
I finally got around to wiring my aftermarket seat heaters and I'm hoping I can get a few opinions.
They're each supposed to be on a 15 amp fuse and the kit came with inline 15 amp fuses to wire in. I put the switches in the factory locations and am drawing power from the lighter for one and the 12V accessory outlet for the other. The lighter, not being on switched power, isn't the best place to grab power though, if I forget to shut the heater off it won't go off with the ignition.
Can I replace the original 15 amp fuse for the 12V outlet with a 30 amp, wire both heaters to that circuit with the 15 amp inlines for each? That puts both on a switched circuit, puts a 15 amp fuse on each, and still leaves me the lighter for call phone charger, etc.
I think it makes sense and I think it's ok to do it this way but I'd feel better if somebody could back it up for me.
Old 10-29-2009, 04:40 PM
Default Re: Seat Heater Wiring
Well maybe I can help someone in the future. I wound up calling Rostra today and asked what the current draw was on their heaters. They told me at full power they pull about 4 amps each so I could easily wire both to one 15 amp circuit. I put them both on the 12v acc outlet and all is well.
Old 10-29-2009, 08:56 PM
Rock Warrior 68's Avatar
Last Online: Yesterday 10:58 PM
Images: 6
Rock Warrior 68 is on a distinguished road.
Rock Warrior 68's Photo Albums
Which aftermarket heater did you use? One of the first things I do with a new truck is to install a $5 dollar fuse block (Painless wiring) from Jegs. That gives me 5 slots to hook up may radios etc. I run power direct from the battery to it.
Thanks for your help!
2010 Tundra Rock Warrior DC
Knoxville, TN
Added Options:
Huskey Liners
K&N Air Filter
XM Radio
Dual Band Ham Radio
CB
Line X
Just getting started, more to come...
Old 10-29-2009, 09:20 PM
SKICREW's Avatar
Dealer : GO Toyota
Last Online: Today 02:17 PM
SKICREW is on a distinguished road.
SKICREW's Photo Albums
I too ran both my front seat heaters off one of the 12V cig outlets, and up the fuse to a 20, no problems even when i use the outlet in conjunction with the heaters.. Best mod ever!!!
Old 10-30-2009, 02:24 PM
I bought the Rostra WET heaters. With careful drilling the round switches just fit into the width of the factory blanks and the seats heat up fast.
Old 10-30-2009, 02:37 PM
SE2000's Avatar
Dealer : Northway Motor Car Corp.
- Other -,
2008 Toyota Tundra DC Blue Streak
Last Online: Today 10:00 PM
SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything.
SE2000's Photo Albums
Did you install the heaters yourself? How many hog rings needed? how long did it take?
Old 11-02-2009, 09:08 AM
As best I remember is was around 18-20 hog rings per seat. I put Katzkin leather in and the seat heaters, total working time was around 8 hours for front and back.
Old 11-02-2009, 11:03 AM
pistolpete's Avatar
Dealer : Crystal Toyota
2004 Toyota Tundra 4X4 SR5 Double Cab
Last Online: Today 07:53 PM
Images: 163
pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all.
pistolpete's Photo Albums
Did you put heaters in your back seat??? or when you say back you mean the lumbar portion of the front seat??? if you did put a set in the back where did you place the switches for those units???
Pistol Pete
#1 COLTS fan!!!!
2004 Toyota Tundra Double Cab 4X4 (7844A), Phantom Grey Pearl, All weather guard package, fog lamps,keyless entry, 17" AA wheels, towing package, color-keyed overfenders, 4.1mm Limited Slip Diffy, Delux 3-in-1 JBL stereo, privacy glass, floor mats with sill protectors, bed extender
MODS- Line-X, Retrax, Onki nerf boards (part #328078), Wade vent visors (part #88401) , TracRac (rail # OL-21609), Ultimate Fly Fishing Rod transporter, Spin Caster Rod holder in bed, Recon bedlights fully adjustable w/"nightvision", HitchSafe, Weathertech floor liners (part #46030-1&2, grey), debadged, visors destickered, rear window stop disabled, dynolock/PL8500 power tailgate lock, tailgate protector mod with detachable floormat, Stebel Nautilus Compact Truck Air horn (300Hz), quick fist flashlight holder (all in photo gallery).....more custom suprises on the way!!
New members from the MidAtlantic (PA,OH,WV,VA,MD,DE,NY,NJ,DC) don't forget to check into the MidAtlantic Forum and introduce yourself!!!
Old 11-04-2009, 11:36 AM
I only heated the front seats, Pete. I read a lot of positive comments on the forum about the Rostra heaters and they do work great. I can't keep them on the high setting for very long because it gets too hot. Once everything is nice and warm turning it down on low is perfect and the pads were long enough to cover a lot of seat cushion and seat back.
