Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 07-29-2003, 08:06 AM
Dealer : Towne Toyota
2003 Toyota Tundra
Last Online: 06-27-2007 06:23 AM
primerhead is on a distinguished road.
primerhead's Photo Albums
Question Left Kick Panel Removal
Need help with removal of the Left Kick panel on a 03 Limited.
Panel removal necessary to gain access to the sub wire harness
connector for a brake controller install.
Any help with panel removal info would be appreciated.
Thanks
Paul
Old 07-29-2003, 09:49 AM
Gilley's Avatar
Dealer : Courtesy Toyota Scion of Orlando
2003 Toyota Tundra
Last Online: 10-22-2007 02:18 PM
Gilley is on a distinguished road.
Gilley's Photo Albums
Remove the sill cover for the front door (4 screws) and then remove the plastic hex nut on the kick panel itself. Grab the front of the kick panel and gently pull it toward you to get it off of the threaded stud that the plastic hex nut is on. Finally, pull on the kick panel to release it from the clips between the dash and door jamb. Pretty simple.
Install in reverse order and make sure the clips line up to the holes on the panel and still cover.
