This is a discussion thread titled "Center arm rest vibration", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-01-2003, 11:54 AM
dwagner825's Avatar
Dealer : Rouen Toyota of Maumee
2006 Toyota Tundra,
1999 Toyota Sienna
dwagner825's Photo Albums
Last Online: Today 09:20 AM
dwagner825 is on a distinguished road.
Unhappy Center arm rest vibration
I am experiencing severe vibration on my 2000 Tundra's front bench seats center arm rest. It only occurs when going over bumps. it it so severe it splashes any drink in the cup holders all over the car. Earlier in the year someone posted having the same problem and the dealer fixed it with some sort of padding under the seat mounts. Any suggestions since I can't find that original thread.
Dan
Old 08-01-2003, 12:07 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
nhparrot's Photo Albums
Last Online: Today 01:27 PM
nhparrot will become famous soon enough.nhparrot will become famous soon enough.
See TSB NV014-00 dated 9/15/200 and titled CENTER ARM REST VIBRATION in the Service Bulletins Database
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 08-03-2003, 01:47 AM
Dealer : Charles Maund Toyota
2002 Toyota Tundra,
- Other - 2005 infiniti g35 cp
mikeinaustin's Photo Albums
Last Online: 09-29-2008 03:29 PM
mikeinaustin is on a distinguished road.
unfortunatly i believe that tsb covers 2000 tundras, i have a 2002 and the center armrest (the one with two cupholders on 60/40 setups) is unusable because of massive vibration. also makes a lot of noise on bumby roads.
Old 08-07-2003, 12:14 AM
2002 Toyota Tundra,
i don't know what to do. i took it all apart once, greased where there was a bit of metal to metal contact (just to get rid of some of the noise, not to reduce the vibration), etc.
i've heard of others removing the passenger seat and putting "pads" where it bolts to the body - not ready to do this yet.
i could take it to the dealer, but i'm afraid all they will do is :
1) screw things up even worse
2) say its normal
Old 08-07-2003, 02:10 PM
amesjustin's Avatar
2003 Toyota Tundra extended cab sr5
amesjustin's Photo Albums
Last Online: 01-26-2007 08:46 PM
amesjustin is on a distinguished road.
Send a message via Yahoo to amesjustin
Well, they have the same problem in the 2003s. I get a cup of coffee every morning for my commute in - ever since I bought the Tundra I have had to down half of it to prevent massive spillage. And that is with with the lid on. I tried using the in-dash cupholders and onle ended up spraying hot coffee all over the radio....
Old 06-04-2005, 06:10 AM
ToyzOnly's Avatar
Dealer : Folsom Lake Toyota Scion
1998 Toyota Avalon XLS
ToyzOnly's Photo Albums
Last Online: 09-01-2008 12:04 AM
ToyzOnly is on a distinguished road.
Default ressurected thread
....found this old thread on a search.
anyone else with center armrest vibration with the 60/40 bench seat?
Fixes, ideas, suggestions???
Old 06-04-2005, 10:49 AM
confederate2's Avatar
Dealer : Price Leblanc Toyota
2003 Toyota Tundra
confederate2's Photo Albums
Last Online: 09-22-2008 05:09 PM
confederate2 is on a distinguished road.
Nope, mine is smooth as silk for the last 2 and half years. Now I have to say that I have never ridden with the center console in the up position, only down. But no problems at all.
Sammy
2003 TRD Stepside 2WD LSD, 275 Revos, 1 inch Daystar spacer up front, TRD AALs in the back, 1.5 inch Wheeladapter.com wheel adapters, Truxedo tonneau cover, Rhino Lining, Self-Dimming Mirror w/Compass & Temperature, RS3200 Alarm Upgrade, Stant 11506 Locking Gas Cap, Hellwig Anti-Sway Bar, Magnaflow 12586 on the way
Old 07-16-2005, 10:18 PM
H2O_MAN's Avatar
Official Taste Tester
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN's Photo Albums
H2O_MAN is on a distinguished road.
I ordered the repair kit listed in the TSB and upon inspection I found my '02 already has the upgrade from the factory.
The upgrade is a design change and should be included on '03 and '04 models.
The two metal supports that the console pivots on seem to be the problem.
I have no idea how to fix this... Now to return the kit for a refund.
You never feel as big as you do when you're with a pygmy
http://www.fairtax.org/
Old 09-05-2005, 08:22 AM
H2O_MAN's Avatar
Arrow I fixed it!
I cured the flopping fold down center console condition on my 40/60 bench seat.
My step by step "how to" -- sorry no pictures.
Remove 4 bolts, un-plug the wire and remove the passenger side seat - set aside.
Remove the 4 bolts holding the black plastic, flat "dog bone" to the transmission tunnel.
Flip the dog bone over and note the reinforced spine running down the center, front to back.
This center arch needs to be lifted up from the floor in the rear.
For a shim I cut the head and neck off of an old REACH toothbrush and placed the
remaining handle portion on the carpet with the widest part of the grip facing the bed.
The spine of the dog bone makes a clear impression in the carpet that can be used as a guide.
I then centered the dog bone over the toothbrush handle and bolted it into place making sure
the rear of the spine was centered directly over the widest (shoulder) portion of the handle.
Make sure everything is centered then tighten all 4 bolts on the dog bone.
Now re-install the seat, plug in the wire and bolt into place.
I hope this helps. -- Mine is rock solid now
Old 09-05-2005, 08:43 AM
ToyzOnly's Avatar
Thank s for the input! Think I'll try that when I get a chance!
Old 05-16-2007, 11:44 PM
2004 Toyota Tundra,
- Other - AC LTD 4X4 TRD
evenfall's Photo Albums
Last Online: Today 12:12 AM
evenfall is on a distinguished road.
Default Re: Center arm rest vibration
OK, I'm thinking it is time to give this thread a bump... Proof I searched first anyway...
Yup, my armrest is a bit overactive. Called the local dealers and well... You know service writers... people who do not actually fix cars, and likely do not know how, either... They pretend to listen to what you describe and have no clue at all concerning what you are telling them until they say, ahhhh sorry sir but there is nothing like this I have ever heard of... No TSB that I know of.
The guy I spoke with did not even know anything about and TSB of this type ever. Plus you know, they give zero advice, they want you to bring it in...
So what's the latest on this guys? Have any more of you fooled around trying to make the armrest vibe prob become more tolerable?
~evenfall~
~Phantom Gray Pearl~
Old 06-30-2007, 12:32 AM
Dealer : Rochester Toyota Scion
cleggy's Photo Albums
Last Online: 09-30-2008 11:54 PM
cleggy is on a distinguished road.
I have a 2000 with the TSB done but it still vibrated. I found a gray/blue folded up bath towel that matched the upholstery and wedged it tightly under the console. That did the trick and made it solid. If you fold it up carefully; you can't see it and best of all, it was free.
