Originally posted by geneowens A Toy dealer and a truck aftermarket dealer both told me that the bars for the Access Cab would "NOT" fit my Reg Cab - Apparently the frames are not the same.
that sounds like fud to me...i remember when i was buying my truck and looking at pamphlets, they only show one, yep one, frame for the tundra, so the extended step bars i think from waag should do the trick. there's surely a difference in mount points for the cab and bed, but i really doubt the frame itself is different. if you buy bars that go between the cab/bed to frame mounts, then no they will not work.
otherwise, i know you said no custom stuff, but in reality a 4x4 shop could fab up a simple nerf & step bar without too much trouble, since it's easier than a slider bar, and they could do the bolting for you, using existing holes...custom fab is handy like that.
-sean
