Unichip.com
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 09-07-2003, 01:39 PM
Dealer : Hank Aaron Toyota
2002 Toyota Tundra
Last Online: 07-01-2007 08:23 PM
Wadesters is on a distinguished road.
Wadesters's Photo Albums
Default Is it possible to modify the driver seat to go back further for tall owners??
I have a 2002 SR5 4WD Tundra. So far I really like it. The only problem I have is with the driver seat. I am tall and would be more comfortable if the seat went back a little further. I looked at the bolt position and it does not appear to be an easy fix. Does anyone else have this problem? Have you made any modifications?
Thanks...
Old 09-07-2003, 10:14 PM
wes 03's Avatar
Dealer : Durant Toyota
2003 Toyota Tundra
Last Online: 03-06-2008 09:02 AM
wes 03 is on a distinguished road.
Send a message via AIM to wes 03 Send a message via Yahoo to wes 03 wes 03's Photo Albums
i want to know this too
wes
Old 09-08-2003, 11:41 AM
makana81's Avatar
Last Online: 07-08-2005 05:38 PM
makana81 is on a distinguished road.
makana81's Photo Albums
You could always attempt it yourself---get four 1/4" (minimum thickness) x 2" (wide) x ? (distance to move seat back plus 1") steel plates. Drill 4 holes slightly larger on one end of the plate and drill & tap another 4 holes 10 mm x 1.25 on other side of bracket.
Note: The addittional 1" clearance is to move the drilled locations 1/2" in from edges minimally---increased clearance ups the rigidity.
Make sure you pick up more bolts (4 each 10mm x 1.25 x 30mm [dependent of thickness of plate purchased]), these will be used to fit thru the slightly larger drilled holes and mount to the original locations with the longer bolts. The 4 bolts removed earlier will be used to mount to the brackets drilled & tapped holes.
Added benefit to the mod is the raising of the seat.
Or, take the seat out of the truck and to a metal/welding shop, they should be able to fabricate mounting relocation brackets that move the seat back a few inches. Just ensure you clearly explain what you want.
Hope this insight helps, Good Luck.
Old 09-08-2003, 05:18 PM
Dealer : Power Toyota Cerritos
2006 Toyota 4Runner
Last Online: 03-21-2009 09:42 PM
turyates is on a distinguished road.
turyates's Photo Albums
I used a peice of flat iron on the front, 4 inches long 1 inch wide 3/8th thick with a lip welded on the top, so it looked like an unside down " L" . in the back I used a piece of 2 inch square tubing. Drilled them out, needed longer bolts for the front floor mounts, the back I used the factory bolts plus 4 bolts and nuts for the seat to the new brackets. The seat only went back about half an inch but up just over two. If I went back more, than I would have to reach too far for the dash, as it is I had to get a longer knob for the gear shift. But my leg doesn't rub against the door any more and I can shift smoother now. If you try this, make sure that the front bracket has the same angle as the seat bracket, the rest is easy to do with only hand tools.
Old 09-30-2003, 12:40 AM
Last Online: 05-09-2007 03:05 PM
treberg is on a distinguished road.
treberg's Photo Albums
I think the best way is to get a tundra with a power seat. I am 6'3" 240 and the power seat provides plenty of room. I have been in one without a power seat and its a bit tight for me.
Old 10-02-2003, 03:49 PM
2002 Toyota Tundra
Thanks for the info.
I wonder what the cost would be to change to a power seat. I would assume you could use the same seat just different tracks and the motor. I will look into it.
That is really the only thing I do not like about the Truck.
Old 10-06-2003, 12:47 PM
Dealer : Maplewood Toyota
2007 Toyota FJ Cruiser Black Cherry 4x4,
2006 Toyota Tundra DC SR5 TRD 4WD V8
Last Online: 06-21-2009 09:02 PM
RockLobster is on a distinguished road.
RockLobster's Photo Albums
I have the same problem. I am 6'4" and all legs. My last truck (nissan pathfinder) driver's seat went so far back i almost coulnt push the pedals all the way down sitting up as straight as possible. (But then my head hit the roof).
My O3 tundra SR5 dosnt have the power drivers seat and it would be nice if it went back 2" or so further. I noticed it first thing when I got in the truck at the dealership. But after driving it, it's not uncomfortable just a little different.
I have read that the reason for it is to maintain proper distance from the airbag. If you are too far away you will hit the airbag at the wrong time and end up hitting the steering wheel. That is the main reason I have not changed it. But i think I will look at it to see If I can do something different.
2006 Tundra DC SR5 4WD V8
1991 Mazda RX-7 Turbo
Old 10-06-2003, 01:33 PM
2002 Toyota Tundra
HI, thanks for your input. I have herd that with a driver side power seat the seat goes back further. I have not had a chance to check this out to see if it is true. I am hoping that it is. Not sure the cost involved to change over. I will more than likely have my truck a long time so the change may be worth it for me. Regards...
Old 10-16-2003, 10:46 PM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel,
2009 Toyota Matrix Pontiac Vibe
Last Online: 02-06-2009 09:53 PM
file014 may have some regrets.
file014's Photo Albums
Talking
I have a regcab truck and I too am tall, 6'2". How do I make my seat go back farther?
Old 10-17-2003, 12:05 AM
DEM DEM is offline
Last Online: 10-18-2003 07:00 AM
DEM is on a distinguished road.
DEM's Photo Albums
Did you find out about the cost of this and if it can be done. I am interested also because of my long legs!
Old 12-22-2003, 04:01 PM
BT-22's Avatar
Dealer : Frank Smith Toyota
2005 Toyota Tundra SR5 DoubleCab
Last Online: 07-02-2009 05:54 PM
Images: 2
BT-22 is on a distinguished road.
BT-22's Photo Albums
let me know also.
thanx
MODS:
20"Enkei Wheels--Red Top Optima Bat--LineX Bedliner
Old 12-22-2003, 04:08 PM
2002 Toyota Tundra
Hi, recently I went to a dealer and sat in a Tundra with power seats. They do not go back further than the non-power. So far I have hit dead ends in all ways of trying a fix. I can live with it but would rather not.
Regards...
Old 12-22-2003, 04:46 PM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Yesterday 11:03 PM
RichR is on a distinguished road.
RichR's Photo Albums
Regards...
Wadesters,
See posts in aftermarket section by UCK40 about seat rail modification.
I also remember a mod to slightly lift the seats to give a lil more leg room.
HTH,
RichR
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Old 12-22-2003, 05:17 PM
2002 Toyota Tundra
Rich, Great news, I will try it over the holidays. The only thing that concerns me is mine is a split bench not a bucket seat. At any rate I am going to take it out to see what I can do. Grinding off tabs on the original seat is of some concern to me. I would rather pay someone so if they screw it up they have to fix it. But I'll try since I do not know anyone that would do this kind of work.
Thanks again...
Old 12-22-2003, 08:10 PM
mandzach's Avatar
mandzach
Dealer : Findlay Toyota Scion
2003 Toyota Tundra,
2007 Toyota Tacoma SILVER-DC-OR-4x4
Last Online: 10-12-2007 11:40 PM
mandzach is on a distinguished road.
mandzach's Photo Albums
Default ditto
my feelings exactly- front seat wont go back far enough and front end of truck nose down stance only two things i dislike on the truck.
2007 Tacoma 4x4 DC/SB - Total Chaos UCA's, Donaho Racing CO's, Deaver Springs, 33" Toyo MT's
.................................................. .................................................> Built for Desert Fun!
Need Tranny Mods?--> IPT Valvebody calibration IPT Transmissions
LinkBack to this Thread: http://www.tundrasolutions.com/forums/interior-and-exterior/18940-possible-modify-driver-seat-go-back/
Posted By For Type Date
The seat doesn't go back far enough - Tech with a twist of lime! & FLHybrid Club. This thread Refback 05-05-2008 09:32 PM
The seat doesn't go back far enough - Tech with a twist of lime! & FLHybrid Club. This thread Refback 10-27-2007 04:41 PM
