Originally Posted by e_j_m
... While we're on the subject, can someone tell me about mounting the factory hood protector? Will I need to drill holes all the way through my hood?
Thanks for any help
No, not through the hood. You will need to drill through some of the formed support sheet metal under the front of the hood.
Mounted the OEM hood protector on my '03. Two 3/8" holes drilled in the support material in the hood near where the rubber bumpers land (on the underside of the front of the hood) on both sides. No worries. I used a Q-tip and a litle 3M rust preventative paint on the drilled holes after drilling and before installing the rubber compression-nut fitting.
When I read the directions I was a little skittish but after looking where I was to drill, I smoothed out. Use a good bit, a smaller one first, then the 3/8." Follow the directions to a 'T' and you'll like the fit. I waxed the front of the hood several times before I installed the piece. I won't feel so guilty about it now when I can't quite get to the hard-to-reach places.
Pete
