Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 03-28-2002, 03:49 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 02:18 PM
nhparrot's Photo Albums
Default The shift lever
Topic: The shift lever
hovisimo
TS Supporter
Member # 378
Member Rated:
posted 03-18-2002 08:39 AM
if you're on a rather steep hill, or parked with one wheel on a curb or something like that, the truck is being held in place by the transmission being in park (i'm sure everyone knows that) but if you don't press on the brake hard enough to keep the truck from moving when you release it from park, it will make a noise when the gears disengage. this probably isn't a good idea, i step on the brake to prevent it - this is the noise you probably heard, though.
-Ryan
my page
Posts: 248 | From: Pennsylvania | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Platinum TS Supporter
Member # 73
Member Rated:
posted 03-14-2002 02:27 PM
quote:
Originally posted by Cappi:
Imdone,
To stop this from happening on inclines do the following.
When arriving...
*apply the emergency brake before putting the truck in "Park" and letting your foot off your brakes
When your ready to go...
*put your foot on your brakes and shift out of "Park" ...then let off the emergency.
This is what I do and have no problems.
2001, SR5, V8, 4x2, Access Cab, Metallic Silver Sky
MODS: Better Built alum toolbox w/lights 2 inside 2 outside, lots of antennas, CB/Ham/Scanner/linear amp all mounted in custom made console, 10 disc CD player, DEI Sidewinder 5000 ESP alarm, undercarriage entry lights, extra set 55W reverse lights, underhood light, TRD add-a-leaf (ordered), Lund bugshield, chrome step tubes, UTR bedliner, hitch, tinted windows, fuzzbuster hard wired, 4 block power terminal under dash, 12V Acc plug engine compartment, synthetic oils, fog light mod, cargo light mod, acc plug mod, map light mod, back seat angle mod soon, 2 TS stickers (back windows), 2 TS license plate frames (front, rear)
Posts: 461 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
Cappi
TS Supporter
Member # 2594
Rate Member posted 03-14-2002 11:30 AM
Imdone,
When arriving...
2001 Tundra, SR5/TRD 4x4, V8, w/ rhino bed liner
Posts: 7 | From: PA | Registered: Mar 2002 | IP: Logged
Imdone
TS Supporter
Member # 2203
Member Rated:
posted 03-01-2002 03:54 PM
I have only found that mine shifts hard if I am parked on any type of incline. If the truck is level then there is no problem. I do however step on the brake habitually hard being from the pre-tundra school of manual brakes. I get into my truck and its like the pedal falls to the floor when I step on it. That's probably just me though.
I have no clue how this came to be...
Posts: 70 | From: The Desert | Registered: Feb 2002 | IP: Logged
Tundra_Jules
TS Supporter
Member # 1506
Member Rated:
posted 02-22-2002 09:44 PM
I haven't noticed any difference between my truck and other vehicles with this feature. I did test drive a few Ford trucks before I bought my Tundra and I have driven a couple different Tundra's also. I didn't notice any difference. I have 30k miles on my truck now and never had the problem you people are describing.
Posts: 117 | From: San Diego, CA | Registered: Feb 2002 | IP: Logged
Agent WD-40
TS Supporter
Member # 330
Member Rated:
posted 02-20-2002 06:03 PM
I had the same problem when my truck was new too. It doesn’t do it anymore though. Nothing with the truck changed though. I have just gotten used to pressing on the pedal firmly before I go to take it out of park. You have to press the pedal much harder on the Tundra than any other vehicle I have ever driven. It gave me a lot of grief when I first got the truck. I just got used to it and now it is habit to press firmly on the pedal. Sometimes I still don’t press hard enough and I can’t get it in gear. I just let go of everything and start over. If you keep pressure on the shift lever and press the pedal harder it wont go into gear either. You need to remove pressure to let the lock pin slide out of the way and then you can put it in gear. Hope this helps.
I’m trickier than MacGyver with a roll of duct tape.
Posts: 46 | From: Davis, CA | Registered: Feb 2002 | IP: Logged
alexcue
TS Supporter
Member # 1337
Member Rated:
posted 02-20-2002 05:19 PM
Boy am i glad i found this place! I was having the same trouble the other morning. I couldn't get it to shift into any gear. I finally stomped on the brake and then it seemed to release the lever. I attributed to it being a new truck and needed to work itself out, but it's happened again at least once. If it keeps up I'll have it checked out, but you know how these non-recurring bugs seem to never happen when the dealer has them
My Tacoma had the opposite problem when it was brand new, it would pop out of gear under acceleration at the worst times. Luckily the dealer was able to replicate it, but he was about the give up, himself. Turns out the bezel was not set right and the gear wouldn't fall into place.
2002 SR5 Access Cab
Posts: 27 | From: Los Angeles, CA | Registered: Feb 2002 | IP: Logged
Ohio Tundra
TS Member
Member # 367
Member Rated:
posted 02-17-2002 02:09 PM
Mine is extremely hard sometimes too. Even after I push the brake all the way down it takes a second sometimes. I believe it is mostly when it's cold though. Does anyone out there know of an adjustment?
2001 Tundra limited 4x4, Sunfire red with the color keyed package.
Posts: 48 | From: Greenville, Ohio | Registered: Feb 2002 | IP: Logged
Lazy Ace
TS Supporter
Member # 988
Member Rated:
posted 02-17-2002 01:48 PM
My guess is that there must be an adjustment between the break pedal and the switch. On mine, all I have to do is just barely press on the brake and the shift lever will move easily. If such an adjustment exists perhaps the throw can be shortened.
Goodbye Waymore
Posts: 29 | From: Dallas, Oregon | Registered: Feb 2002 | IP: Logged
Mohamed
TS Member
Member # 589
Rate Member posted 02-17-2002 12:39 PM
quote:
Originally posted by Jwitz:
do you mean the 4wd shift lever or the stick shifter on the manuals (gee wasn't that redundant)... I haven't found a need to press the brake for either, with the exception of stopping the truck to go into 4lo...
Nah...not stick shift, that would kinda be hard to shift stick with your brake on, while driving...hehe !
I mean the auto column shift lever. All autos require you to depress the brake pedal, but mine you have to depress really far down, unsual than any other car/truck I have ever driven. That's why I wanna see if others have the same problem or if it's just mine that may have something out of wack!
Are you okay...you've been hit, you've been struck by a...SMOOTH CRIMINAL
Other pics of My Tundra
Posts: 95 | From: Carmichael, CA | Registered: Feb 2002 | IP: Logged
Jwitz
TS Supporter
Member # 119
Member Rated:
posted 02-17-2002 11:37 AM
Just roll with it...
2001 Tundra SR5 V6 5spd 4x4
2.5" Fabtech lift w/ rear add a leafs, JL, Rockford, Pioneer stereo system, CB radio, Homemade diff breathers and sway bar disconnects, 31" Duler A/T's on the stock rims
Posts: 88 | From: Auburn, AL | Registered: Feb 2002 | IP: Logged
Mohamed
TS Member
Member # 589
Rate Member posted 02-16-2002 07:25 PM
ya I know we moan and b$@*#h sometimes here about certain ridiculous things, so here's mine.
At work I drive pretty much the big three. GSA trucks: S-10 and Ram (this one is really fun to drive). The big econoline van we have is estiennally the same lever found in the F-150's Ford. I can honestly say each has a really easy shift lever. The tundra's is rather tough and one time I heard a really bad clunk as I shifted with the tundra's, almost scared me like I broke a tooth or something (off one of the gears). Pretty much I found out your supposed to depress the brake a good amount to shift that lever, not some dinky press.
Anyone else have that, or I might have something out of adjustment (as far as depressing the brake pedal).
Old 09-11-2005, 10:45 PM
Dealer : Marietta Toyota Scion
2005 Toyota Tundra
Last Online: 11-07-2009 03:23 PM
Jim S. is on a distinguished road.
Jim S.'s Photo Albums
Default Automatic Transmission Shift Lever
I've noticed that the automatic transmission shift lever on my 05 double cab will jerk distinctly when the lever is placed in park on a slight hill. The movement is actually in two phases: sort of ker-klick as the lever moves in a two step jerking movement.
I've driven a lot of auto shift vehicles (American cars) and none of them exhibited this jerky shift lever movement when placing the shift lever into park, even on a hill.
Is anyone else having the same problem?
