This is a discussion thread titled "Water Leak In Rear behind Seat X-cab", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 11-17-2003, 01:38 PM
Inactive Account
billz's Photo Albums
Last Online: 04-20-2004 10:13 AM
billz is on a distinguished road.
Unhappy Water Leak In Rear behind Seat X-cab
Has anyone come across a water leak in their access cab on both sides of rear seat on carpet.Looks like It might be comming in under rubber roof strips into rear window but I dunno ??
Old 11-17-2003, 02:10 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 04:30 PM
it might be coming in through the cab vents behind the seat. removing the back seat is very easy, there are four bolts, and the whole thing lifts up and out. under the black plastic flaps you will find the vents, check for leaks there.
-sean
GFX by FreedomEagle50
Manual Hubs
Old 02-22-2004, 01:19 PM
romar's Avatar
Dealer : Boch Toyota South
romar's Photo Albums
Last Online: 09-20-2008 10:13 AM
romar is on a distinguished road.
I removed my rear slider and found two "air bubbles" or holes in the original wet seal. These holes were located adjacent to the two top screws that hold the slider in place. I cut the wet seal in a "V" to remove these holes, filled them with some high grade silicone then applied a small bead all the way around the original seal. "Volla", leak is gone and carpet is dry.
Old 03-07-2006, 10:03 PM
mmarlatt's Avatar
Dealer : Lithia Toyota of Vacaville
2003 Toyota Tundra
mmarlatt's Photo Albums
Last Online: 08-28-2008 12:36 PM
mmarlatt is on a distinguished road.
Send a message via AIM to mmarlatt
Default Re: Water Leak In Rear behind Seat X-cab
I found a leak today. I guess I'll check along the back wall. Has anyone else found their leaks in another place?
2003 Stratosphere Mica SR5 Access Cab
Shocks: Bilstein 5100 coilovers and 5100s in the rear.
Wheels: Toyo Open Country A/T 275/70/16s on MB Blitz rims
Old 03-13-2006, 09:25 PM
atrdnut's Avatar
2003 Toyota Tundra
atrdnut's Photo Albums
Last Online: 07-30-2008 08:35 PM
atrdnut is on a distinguished road.
Send a message via AIM to atrdnut
No leaks in my '03 Access Cab.
I agree with Sean - temporarily remove the rear seat so you can get a better vantage point with your situation. Good luck!
-Austin
2003 Toyota Tundra SR5 TRD Sport
Old 03-14-2006, 12:03 AM
mmarlatt's Avatar
2003 Toyota Tundra
It is in the air vent on the cab wall. I found it, but it rained all weekend so I couldn't fix.
Old 04-07-2006, 10:48 PM
joker7037's Avatar
Dealer : Wiese Toyota
2008 Toyota Tundra SR5 Double cab,
2004 Toyota Tundra SR5 Access cab
joker7037's Photo Albums
Last Online: 10-07-2008 02:54 AM
joker7037 is on a distinguished road.
Do you have an update to this issue? Mine is donig the same thing, rear
carpet looks exactly like the picture.
Just wanted to know if you got it fixed.
thanks,
chris
Interior: Catch all extreme front floor mat, Custom stereo (JL, XM, and Alpine), Rear seat 1 inch spacers (for amp), Window tint, Radar detector
Exterior: Front skid plate, Black headlights, Debadged tailgate, Rcd lift 6", 17x9 Helo Maxx6 black, 285/70/r17 BFG TA/KO, TYC black taillights, Under hood lights, Westin step tubes, Single in dual out Flow Master, Billet fuse box cover, Billet throttle body cover, Line-x bedliner with Toyota logo, Manual hub conversion kit with Aisin hu
bs
Old 04-08-2006, 08:20 AM
cdc's Avatar
cdc cdc is offline
2003 Toyota Tundra
cdc's Photo Albums
Last Online: 03-21-2007 09:36 PM
cdc is on a distinguished road.
I first noticed a leak at the top of my back window, it dripped in the middle. Had it serviced....rained cats/dogs and now there are 2 leaks!!! On either side of the sliding middle window. Soaked the left back seat pretty good. Going back Mon. for them to do a "water test". Man, I hate water leaks, seems like they never get fixed right. Will it be better to get a new window and start over or agree to try and have this one fixed...again? Or could it be coming from someplace totally different?
Old 04-08-2006, 11:08 PM
romar's Avatar
That is almost exactly what my carpet looked like. The only difference was when I noticed my leak there was what I believe to be a ginger snap my daughter must have dropped covered in mold.. UUGHH!! It's been two years now since my fix and my carpet has been dry since. I really don't remember all that well but it is possible that your rear slider could be leaking and the water is running down and around the vents. The one thing I do remember was that without taking the interior trim off the rear slider, you couldn't tell it was leaking.
Black 2000 SR5 AccessCab V8 4x4 / Debadged / Tow package / Factory Bedliner / Trans. rebuilt @ 72k / Stone Mountain headers / Flowmaster 50 series dual out the side / chrome tips / slotted and drilled rotors / air box mod / power outlet mod
Old 04-08-2006, 11:21 PM
romar's Avatar
Hmmm.. did'nt seem like my last post went through. I guess it did..
Old 04-09-2006, 01:14 AM
mmarlatt's Avatar
2003 Toyota Tundra
thanks,
chris
Yep. I haven't had any water since I filled in a silicone bead around both air vents. I knew it was the driver side air vent that was leaking because I recreated the leak with my garden hose.
Old 04-09-2006, 01:46 AM
biggary's Avatar
Dealer : Earnhardt Toyota
2001 Toyota Tundra,
2004 Toyota Camry-Solara
biggary's Photo Albums
Last Online: 11-11-2008 10:57 AM
biggary is on a distinguished road.
I removed the third brake light assembly to install the antenna for my satelite radio and discovered a small leak afterwards. A little more silicone around the housing stopped that and it hasn't leaked since.
Factory: Leather, Tow Pkg., Tundra Floor Mats, RS 3000 Security, Six Disc In-dash CD Changer, TRD Off Road Package, Toyota bed extender, auto-dimming mirror, and running boards
Add-ons: INYATI bed liner, Lund hood deflector, Stainless Billet grille, Full tint, Tundra Door sill protectors, Putco s/s bed caps, Delta polished aluminum tool box, Whelen four-way strobe, Bridgestone Dueler A/T Revos 275/70/16's, Throttle Body and Relay/Fuse Billet Covers
Performance: True Flow intake and air filter, 20% Underdrive pulley, Jet Hot SS Autochrome Headers, Power Stop Cross-drilled Rotors & Maxxis Pads, Flowmaster cat-back dual exhaust.
Audio: Alpine V12 amp, Kicker two-way front speakers, Rockford-Fosgate two-way rear speakers, Boston Rally Neo 3r tweets, Phoenix Gold 500.1 sub amp, Twin Rockford-Fosgate 8's in a Q Logic sub enclosure, sound deadening, XM SKYFi2 Satellite Radio
Suspension: Revtek 2.5" suspension lift ,1.5" rear leveling block, Hellwig anti-sway bar w/ ADDCO end links, TRD Red/Blue shocks, TRD Add-a-leafs
Mods: Rear seat angle, Dome/ Dash/Fog/DRL and Cargo Light Mods,Under carriage lights, Ignition Key and Open Door Chime Mods, Silverstar head and fog lamps, Power tailgate lock
Old 04-17-2006, 04:20 PM
japes's Avatar
Dealer : Roseville Toyota Scion
japes's Photo Albums
Last Online: 06-11-2008 02:07 PM
japes is on a distinguished road.
Send a message via MSN to japes
I noticed this leak a couple of months ago I will have to try the silicon idea.
Revtek 2.5 spacer lift ~ Wheelers AAl's ~ Motto MT700 16x8 & 285/75 BFGoodrich All-Terrain T/A KO's ~ Alpine 9813 ~ Phoenix Gold OCTANE-R 8.0:4 ~ JL 6.5 xr comps ~ JL 6.5 xr coax's ~ JL Stealth Sub ~ Q-Logic with JL Audio 8w3v2's ~ Flowmasters After cat exhaust ~ Trenz billet grill ~ clear corners ~ Rhino lineing ~
Old 04-18-2006, 12:37 AM
mmarlatt's Avatar
2003 Toyota Tundra
Maybe you want to rethink that. I just noticed that my leak has returned. I am going to try automotive goo next. If that doesn't work I will look into removing the bed
Old 04-12-2008, 10:23 PM
Dealer : Classic Toyota Scion of Round Rock
2003 Toyota Tundra
Technikal's Photo Albums
Last Online: Yesterday 12:02 PM
Technikal is on a distinguished road.
Sorry to revive an old thread, but I had this same problem and found the cause and thought I'd post just-in-case anyone else runs into it. On mine, the culprit was a cracked plastic 'drain plug' on the back wall of the cab. You can't see it when removing the rear seat - it's hidden behind the plastic trim on the sides. I removed the trim work in order to find what was leaking, however you won't have to do that to repair the problem - the plug is easily accessible and replaceable from the exterior of the truck, right at the bottom corners of the rear cab wall. I'll post up pics to show exactly where when I get a chance.
I used silicon sealant to fix the problem. I'll try to find a replacement plug one of these days to really fix it.
