Double Cab GVW
+ Reply to Thread
Results 1 to 5 of 5
Thread: Double Cab GVW
  1. #1
    Join Date
    Jun 2003
    Location
    Pleasant Valley, Ca
    Posts
    54
    Liked
    0 times
    Rep Power
    13
    Default Double Cab GVW
    Saw a new double cab a week or so ago and got a spec sheet that states the GVW is 6600 pounds. That's about 550 pounds over my 02 Access Cab. Tires and wheels are the same and axles apear to be the same also. Does anyone know if they actually have beefier components, or did Toyota up the spring rate and use the same Axles as previous years?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Aug 2002
    Location
    Innactive
    Posts
    1,280
    Liked
    0 times
    Images
    9
    Rep Power
    90
    Quote Originally Posted by RKCRUZA
    6600 lbs? That's heavy for a pickup! Though it does break the 6500 lb barrier for small business tax relief on equipment purchases... may be one way they'll move them out the door! (It's worked for Ford and Hummer this last year here on the West coast).
    Jeff
    Account no longer active.
  4. #3
    Join Date
    Jun 2003
    Location
    Pleasant Valley, Ca
    Posts
    54
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    Default Heavy?
    Quote Originally Posted by PXLpainter
    Jeff
    The 6600lbs. is Gross Vehicle weight (as in loaded) so is not heavy at all. My 02 has a GVW of 6040 so I just wondered where they got the extra 550lbs of GVW. Also, the magic number for for vehicle weight is 6001 pounds. Anything over 6000# qualifies for the extra 1st year and Sec 179 write offs.
  5. #4
    Banned
    Join Date
    Sep 2000
    Location
    in timeout
    Age
    37
    Posts
    8,335
    Liked
    2 times
    Images
    100
    Rep Power
    0
    Jeff
    to me when i looked under the tundra it looked the same as the pasted with the new d/c having a bigger axel ratio..the brakes too are the same peice of crap too(bummer toyota didn't use seq disk)
  6. #5
    Junior Member 03SilverSky's Avatar
    Join Date
    Nov 2003
    Location
    The Golden State
    Posts
    373
    Liked
    0 times
    Rep Power
    14
    The DC uses the same i-Force V8 used in the Access Cabs. Is this engine beefy enough for the heavier vehicle? The Sequoia and some '04 4-Runners use the engine also. I think the engine application is great on my Access Cab, but would want more hp for anything heavier.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
