This is a discussion thread titled "Any hints on removing my entire head liner?", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 11-30-2003, 03:21 PM
molex's Avatar
Inactive Account
molex's Photo Albums
Last Online: 11-23-2004 07:07 PM
molex is on a distinguished road.
Unhappy Any hints on removing my entire head liner?
I managed to utterly bungle my attempt to hook up reverse lights via the cargo lamp on the outside of my cab.... the final nail in the coffin was smoke wafting out from between the head liner of the cab and the shoulder belt mounting point, as the delicate wires in the ceiling of the cab (I guess) melted. So now, instead of having a trick reverse/cargo light attached to my rack, I have no reverse/cargo light at all. Yes, I removed the cargo lamp fuse so that it won't start a fire in my cab in the mean-time. Break lights work fine, just no reverse/cargo lamp anymore.
So, I need to take the entire head liner out of my cab so I can track down and fix the burnt wiring.
Anyone done this? Hints, tips, tricks?
Yes, I know: What a bone-head maneuver. Once it's all fixed, I'll pony up the cash to "join the club", then maybe I can get info on wiring my reverse lamps properly without starting a fire!
Old 11-30-2003, 07:31 PM
molex's Avatar
Inactive Account
Originally Posted by hovisimo
it's not hard. remove the 3 plastic plugs holding the rear of the headliner to the roof. remove the dome light, it's held in place by a couple screws. you will need to remove all the plastic trim around the roof... the grab handles are held on with torx screws (i forget the size) and the seatbelt hangers are held on with 14mm bolts, you'll need to pop these off to get the trim off. after that, just pull the headliner down. it's flexible, as long as you don't bend it at too sharp of an angle, it won't crease permanently. you might want to stick some thin carpet padding or sound deadening material between the headliner and the metal roof while you have it off.
I looked pretty closely at it, and what you described is exactly what I thought it would take, I'm glad to hear that there's no secret fasteners or tape or something I can't see that's going to ruin it when I get in there... thanks!
