This is a discussion thread titled "Bed alignment troubles", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-11-2003, 09:56 PM
andybtruckin's Avatar
Dealer : Antioch Toyota Scion
2003 Toyota Tundra
andybtruckin's Photo Albums
Last Online: 03-18-2007 04:04 PM
andybtruckin is on a distinguished road.
Default Bed alignment troubles
I picked up my brand new 03 Tundra the day after Thanksgiving. On the way home I notice that the bed sticks out about a quarter inch on the right side, (I also notice that the steering wheel shimmies at 55-65 mph and the floor mats are missing.) I head back the next day and they order a set of mats and schedule an appt. to fix the shimmy and the bed. They balance the front tires and the shimmy is fixed They tell me to bring it back in three days and their body shop will fix the bed . I take it in today and get a call this afternoon that the bed alignment is not adjustable and that they will escalate to the factory. WTF? They are talking about maybe changing the bed. Has anyone had a similar problem. I would expect this if it were a GMC, I am a bit disapointed in Toyota's quality control as I've been back to the dealer three times for stuff that should have been caught before it was ever put on the lot.
Old 12-11-2003, 10:44 PM
2003 Toyota Tundra
Originally Posted by hovisimo
unless things have changed, the bed is held on by four T50 torx bolts. loosen them and bump it into alignment. don't hold me to this, it may have changed for '04. at any rate it has to be adjustible.
That's what I thought. There are actually six bolts. They say there is no adjustment, I think they are wrong. If this was not a brand new truck I would do it myself. Now that they are getting the factory rep involved I will wait to see what turns up.
Old 12-11-2003, 10:48 PM
Tundrav8yamaha's Avatar
Dealer : Mike Calvert Toyota Scion
- Other - yamaha,
2000 Toyota Tundra (totalled),
2008 Toyota Highlander HV Limited i4wd,
2004 Toyota Tundra Trd Off road Navi
Tundrav8yamaha's Photo Albums
Last Online: Today 06:33 PM
Send a message via AIM to Tundrav8yamaha Send a message via Yahoo to Tundrav8yamaha
Default sounds about right
quality on a tundra aint any different than the big 3 it took toyota 3 year's to get the brakes right on the tundra even still the tundra has some issues it's a give a take issue but it doesnt excuss toyota ...good luck i have been there tooo
T3 Grill, Line X extra front Bumper coating (too many mod's to list)
Old 12-11-2003, 11:38 PM
Dealer : Alderman's Toyota
2003 Toyota Tundra
tm111's Photo Albums
Last Online: 06-23-2007 10:15 AM
tm111 is on a distinguished road.
Default bed alignment fix
I had the same problem with my 2003 when I bought it. I also saw a few others on the lot with the same problem. Anyways, my dealer also tried loosening the bed bolts as that would be the logical solution, but, like yours probably did, found that there is not enough movement to solve the problem.
They sent me over to the main bodyshop they own and the solution was to move the front cab, not the bed. It only has to be shifted a tiny bit to solve the problem. These guys were good, took very little time and the bed is still straight...
I'd bring this up to your dealer if you want it flush on both sides the way it should be.
Good luck,
Ted
Old 12-12-2003, 12:05 AM
TMS2U's Avatar
Dealer : Longo Toyota
TMS2U's Photo Albums
Last Online: Today 12:23 AM
TMS2U is on a distinguished road.
The room for lateral movement is quite small for the bed. The cab is the one that has wiggle room- and its a bit more complex than just loosening up the bed, but it can be done
Old 12-12-2003, 10:32 AM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 04:30 PM
...this is why they came out with those little black plastic shoehorn looking pieces for the bed corners. pretty much every tundra ive ever seen, and many tacomas, have the same issue.
GFX by FreedomEagle50
Manual Hubs
Old 12-14-2003, 05:07 PM
punisher's Avatar
Dealer : Carson Toyota Scion
punisher's Photo Albums
Last Online: 11-18-2008 03:01 PM
punisher is on a distinguished road.
Mine be crooked too on my 2000 4x4. I have learned to live with my less than perfect toy.
Old 12-15-2003, 03:51 PM
hirschg's Avatar
Dealer : Rohrich Toyota
hirschg's Photo Albums
Last Online: 11-14-2006 09:31 PM
hirschg is on a distinguished road.
Question
After reading these posts on bed/cab alignment I checked mine and sure enough it is also out of alignment However my truck is a 2001 with 32,000 miles that I just picked up about a month ago My question would be is this covered uner the warranty or do I just Have to go to my local body shop to get this corrected?
2001 Toyota Tundra Access Cab SR5 4x4 TRD V8 Thunder Gray
Old 12-15-2003, 03:53 PM
hirschg's Avatar
Question
2001 Toyota Tundra 4x4 TRD 4.7L I- Force V-8 Thunder Gray
Old 12-15-2003, 04:11 PM
616269799's Avatar
Dealer : Toyota of Muskogee
2006 Toyota RAV4,
2005 Toyota Camry
616269799's Photo Albums
Last Online: Today 05:56 PM
616269799 is on a distinguished road.
_________________
You should still be under warranty because your truck's less than 3 years old and has less than 36,000 miles on it.
Win or Lose, but Finish the Game
Old 12-15-2003, 09:43 PM
stcj's Avatar
Dealer : Ira Toyota of Danvers
2003 Toyota Tundra
stcj's Photo Albums
Last Online: 09-19-2008 06:30 AM
stcj is on a distinguished road.
Yup, mine is skewed too
Old 12-16-2003, 09:25 AM
d0truji's Avatar
Dealer : Karl Malone Toyota
2003 Toyota Tundra
d0truji's Photo Albums
Last Online: 12-13-2007 03:13 PM
d0truji is on a distinguished road.
So is mine but I would say only by about a quarter of an inch. I can live with it if it's the only problem I have.
TRD Supercharger, TRD Boost Gauge, TRD Duals, 2.5 Inch Cornfed Front End Lift, TRD rear AAL's, Stone Mountain Racing Headers, Wet Okole Seat Covers (Front And Back), Clear Corners, BFG 285/75/16 AT's, American Racing Atlas Rims, Rino Liner.
Old 12-16-2003, 12:34 PM
HJSimpson's Avatar
Dealer : Castle Toyota
2003 Toyota Tundra
HJSimpson's Photo Albums
Last Online: 11-17-2008 08:09 AM
HJSimpson is on a distinguished road.
Default Fixed
I noticed the same problem the first time I washed mine last February. I took it to the dealer for the first (and last) complimentary oil change. Told them to straighten out the bed. The service lane rep said the bed looked fairly straight and there was no way to adjust it anyway. I told them I knew other people (TS members) with the same problem and it is correctable. When I picked up the truck, the bed was straight, but I did not ask how it was done.
My concern was that the protruding edge was going to get chipped up.
Old 12-20-2003, 10:02 PM
dadndudes's Avatar
2003 Toyota Tundra
dadndudes's Photo Albums
Last Online: 08-03-2008 03:56 AM
dadndudes is on a distinguished road.
Mine too, on the passenger side. Noticed it a couple weeks after buying it. Also noticed "ticking" noise from the exhaust manifold and another noise from maybe a belt. Only have 1300 miles and still would'nt trade it for one the "Big 3".
Old 12-21-2003, 10:54 PM
stcj's Avatar
2003 Toyota Tundra
stcj's Photo Albums
I feel the same way.
