This is a discussion thread titled "TRD grill", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-14-2003, 12:33 PM
Dealer : Le Mieux & Son Toyota
greybeards22's Photo Albums
Last Online: Today 02:29 PM
greybeards22 is on a distinguished road.
Default TRD grill
aftr installing new grill I have noticed 'dimples' around grill. maybe from tightening too much to keep my bug deflector in place.can these dimples be corrected? thanks
Old 12-17-2003, 04:34 PM
peid's Avatar
Dealer : Billion Motors
1996 Toyota T100
peid's Photo Albums
Last Online: 11-12-2008 05:44 PM
peid is on a distinguished road.
Some people have experience dimples in their grilles.
If you have a bug shield like the one I do, (Check My Photos) you should had some washers between the grille and shield I believe.
I have mine mounted VERY securely and I don't have any dimples. However, I have the original TRD Style grille which is much beefier than the newer styles. Does yours use t-bolts? If so, it is the newer lighter style. The original ones use studs and weigh literally 2-3 times as much as the newer ones.
1996 T100, 180,000 and counting
Old 12-17-2003, 06:51 PM
what are T bolts? mine have nuts and is light weight. can the dimples be heated up to get back into shape? my shield came loose going thru a car wash so I must of re tightened the nuts toooo much . thanks
Old 12-18-2003, 09:43 AM
peid's Avatar
1996 Toyota T100
peid's Photo Albums
The T-bolts are the "threaded" parts on the grille itself that hold it to the hood. Some grille have T-bolts that "slide" into the grille, other grilles have studs that screw into the grille.
I am guessing you have the form fit bug shield like mine right? I don't go through automatic car washes just for that reason, I would recommend you don't either.
Heating the grille up won't do anything, but rather taking it off and putting additional washers behind it. I also used double face tape on my bug shield instead of the foam that is supplied. The tape keeps it in place and also allows the grille to be much looser which prevents the dimples.
