Originally Posted by Yellbird
Your correct, I just took another look at it. I have one tab left (instead of two) for each hole. Toyota wanted $60.00 for one  so I will give your way a try, Thanks.
Yeah, the dealer replaced mine under warranty. I had the same issue. Ryan's idea will work or you can wrap some tape around it on the bottom where it goes it the whole so that it expands a little more.
If you have them, bigger screws are a better idea but a couple wraps of tape will fill the gap.
Alan
