I can't get that thing off for the life of me!! I removed the bolt on the passenger side, but I can't see how its attached on the driver side. And how that peice of upholstery is attached. Can someone give me some assistance on how to get it off? Please don't tell me you have to remove the whole upper rear seat! Thanks
Exterior-SS Nerf Bars, Bed rails, Delta tool chest, Sylvania silverstars in headlights (removed, burned out too often), Flowmaster Muffler w/2 SS corvette tips, MY foglight mod, K&N FIPK
Interior-Pioneer AVIC-D2, Grey marble dash kit, fluorescent lights, DVD player, AVIC D@ Navigation, TV tuner, Remote start security system, 600w power inverter, 800w Kenwood amplifier, 10" Kicker SoloBaric in custom (My own design & Work!) box
Factory/Port-LSD, power slider, 17" split-spoke alloys, color-keyed:grille, bumper, mirrors, and side moldings, steering wheel audio controls, limited seats, heated side-view mirrors, compass/temp rearview mirror, tow package, heavy duty battery/alternator, in-dash 6cd changer/tape player, tint by Madico, custom glass etching, permavin security, RS3200 VIP security.
The upholstery on the arm rest is secured by a thin zipper at one of the long ends of it. For the seat back there are two long plastic pieces all the way across the back bottom that interlock via 'V' channel on the edge of each piece. That's the best I can describe it. Toyota uses this interlock channel system on most of the seat covers for the tundra.
Doug
Doug
Now that I can get that off, Does anyone know how to detach the whole armrest from the truck?? I need it out of there completely, I know that I will be left with a black bracket behind it, but I can work around that, I just need the armrest part off, like I said I found the bolt holding it on the passenger side, but cant find how it is attached to the bracket on the driver side.
Did anyone ever answer this? I need to remove my rear armrest and I'm in the same predicament. Thanks.
Erik
01 Tundra limited
What the heck, I pulled the entire back seat out and here's what I found: The center armrest assembly is attached to the seatback by two 12mm nuts. Remove them and the armrest assembly pops right out. You can't really remove the armrest simply by removing the pivot bolts on which it rotates because there is a piece of armrest upholstery that is secured by the 12mm nuts--in short, ya gotta remove the whole seat to remove the armrest.
Erik
01 Tundra limited
It's been a while since I did mine, I believe I slipped off the plastic covers that cover the retaining brackets on either side of the armrest/cupholder thingy. Under there there are bolts on either side. I did this to accomodate a bandpass box which squeezes perfectly between the reamining brackets and holds it nice and snug. I like this because I can change the configuration of my rear seat with the box, armrest, both---depending on how many passengers I have.
Sorry, I didn't see your post sooner---hope this helps.
