Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 03-09-2004, 07:10 PM
03SilverSky's Avatar
Dealer : Modesto Toyota World
2003 Toyota Tundra
Last Online: 04-21-2007 12:19 AM
03SilverSky is on a distinguished road.
03SilverSky's Photo Albums
Default Going to Debadge, Last Minute Check
I am going to debadge my truck (see signature for model) tomorrow. I want to remove the SR5 badges as well as the passenger/drivers side door & tailgate badges (excluding the iforce V8 badge).
I want to make sure removing these badges will not leave any holes in the body. Will it?
I also want to know what supplies I will need. I have a ton of dental floss if that will work or do I need fishing line? I also have a can of sray Motsenbocker's Lift Off 2 Tape Romover for adhesives, grease & oily stains. Supposed to zap stickers, crayon & gum. I just hope it doesn't zap clear coat.
Any last minute suggestions will be greatly appreciated.
Built 06/2003 SR5 Acc. Cab V8 Silver Sky Metallic 4x2
Old 03-09-2004, 07:27 PM
ThomasE's Avatar
Dealer : Piercey Toyota Scion
Last Online: 11-23-2009 12:19 PM
ThomasE is on a distinguished road.
ThomasE's Photo Albums
There's no holes behind the badges you listed. I've used both waxed floss and fishing line, they both will work. Most of the mounting tape will roll right off if you rub it with your fingers. I cleaned up the residue with some citrus based cleaner, if you're unsure test it in a hidden spot first.
Old 03-10-2004, 03:00 AM
Possum's Avatar
Dealer : Tejas Toyota
Last Online: 12-28-2007 10:10 AM
Possum is on a distinguished road.
Possum's Photo Albums
Arrow TS Search Engine
Check THIS thread out.
It may be of some help to you.
Good luck!
Dan
DAN
Click on my door and see my interior.
2001 Tundra SR5 V8 Desert Sand Mica
TRD Dual Exhaust | Bilsteins Shocks & HD TRD 4x4 Coil Springs | Hellwig Anti-Sway Bar | Westin Nerf Bars | Stainless Bed Rails | Bed Extender | Bed Liner | Form Fix Hood Protector | Custom Painted IS Grille & Mirror Covers | Stainless Tundra License Plate Frames | Custom Made Receiver Hitch | Totally De-Badged | Super Magnetic Oil Drain Plug | Mobil One Synthetic Oils | Custom Window Etching | Tinted Windows | Muth Signal Mirrors | Door Sill Protectors | Interior Rubber Mats | Gentex Temp & Comp Auto-Dim Rearview Mirror | Weatherflector Ventvisors | TS Decal | Complete Brake Upgrade | Truxedo Tonneau Cover| Michelin LTX M/S Tires
Old 03-10-2004, 11:02 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
IMHO-fishing line will work better than dental floss. After the badges are removed, wash the area with some car wash to clean the area. This should help get rid of the dirt before you start rubbing the adhesive and avoid those fine scratches.
Mike
http://dyogim.blogspot.com
Old 03-10-2004, 11:50 AM
2003 Toyota Tundra
I took off the tailgate this morning and brought it in the house. I used a hair dryer (I have a hot air gun but thought that might be overkill) and detal floss to remove the Toyota Tundra badge. I found that if I doubled the floss I could get through about one letter at a time before it broke. I got a little too eager and cracked the badge between a couple of letters, oops.
I am pleasantly surprised at how easy it was. I am going to do the door badges next. I think I will leave the SR5 badges on for now. I am thinking of taking off my chrome wheel arch mouldings for a cleaner look as well.
Old 03-10-2004, 12:24 PM
peid's Avatar
Dealer : Billion Motors
1996 Toyota T100
Last Online: 01-05-2009 08:49 AM
Images: 31
peid is on a distinguished road.
peid's Photo Albums
Correct me if I am wrong but you took the tailgate off to get the badges off?
That is a first and what seems to be more work than it was worth.
I hope you don't plan on taking the doors off to get the badges off too?
It took me all of 15 minutes to completely debage my truck.
Use some fishing line, gloves and quick detailer spray, remove tape with fingers, and wax.
1996 T100, 180,000 and counting
Old 03-10-2004, 12:50 PM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 12:37 AM
RichR is on a distinguished road.
RichR's Photo Albums
Default My .02
You can also use a cheap plastic putty knife.
I tried both methods.The knife left less adhesive on the truck to get off.
Also I think you will have holes in the fenders where the wheel arch moldings attach.
I left the SR5 badges and TRD stickers on.
RichR
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Old 03-10-2004, 01:33 PM
2003 Toyota Tundra
I have the doors off now but don't remember which one goes on which side!
Old 03-10-2004, 01:35 PM
2003 Toyota Tundra
RichR
I was thinking of puting the bolts back into place to fill the holes, as long as they go in flush...I will see.
Old 03-10-2004, 02:16 PM
gtsv8's Avatar
Last Online: 01-18-2005 10:32 PM
gtsv8 is on a distinguished road.
gtsv8's Photo Albums
Default Fishing string works fine
fishing string works great, some glue remained and little wax removed it
Old 03-10-2004, 02:25 PM
zebra1550's Avatar
Dealer : Performance Toyota Of Lavista
2005 Toyota Tacoma
Last Online: 11-13-2009 04:58 AM
zebra1550 is on a distinguished road.
zebra1550's Photo Albums
You can pull off the tail gate in about 15 seconds with no tools...which is why I leave mine locked all the time. But I do agree, it only took me 15 minutes to debadge my truck as well.
2010 Toyota Tacoma Double Cab 4X4
Magnetic Gray Short Bed w/TRD Off Road Package, Color Matched Hard Tonneau Cover
Old 03-10-2004, 02:42 PM
peid's Avatar
1996 Toyota T100
Images: 31
peid's Photo Albums
Oh I know it is easy to remove the tailgate, but you also run the chance of dropping it, scratching it, denting whatever.
It is big and sort of heavy and just never would have thought of removing the tailgate to debadge. Maybe you are on to something? Or is that "on something?"
If you have the doors off, try putting the suicide doors on the fronts, that way at highway speeds you can get more air flow through the cabin!
Old 03-10-2004, 03:14 PM
2003 Toyota Tundra
Well the wheel arch moldings stay. When I took the front ones off there a clip that sticks out that is attached with a plastic piece that I would have to break and I don't want to. There is alot of crud under those things though. I am going to wash the truck before I stick them back on.
Old 03-10-2004, 03:43 PM
Dealer : David Maus Toyota Scion
Last Online: 12-13-2006 06:32 PM
jbeestundra is on a distinguished road.
jbeestundra's Photo Albums
Default 2000 tundra de badge
Is it too late for me?Do you think after 4 years the paint under the badge will be different?Color is Thunder Gray,Thanks
Old 03-10-2004, 07:30 PM
Last Online: 03-05-2009 01:36 PM
17yrtundra is on a distinguished road.
17yrtundra's Photo Albums
I do believe you will have ghost letters for a little while but after a fwe washes those ghost letter will go right away
