This is a discussion thread titled "Air conditioning and hot water?", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-12-2004, 02:09 AM
5 Speed's Avatar
Dealer : Longo Toyota
5 Speed's Photo Albums
Last Online: Today 03:40 PM
5 Speed is on a distinguished road.
Default Air conditioning and hot water?
I was changing my coolant and was looking at where the heater hose goes inside the cab and realized that unless the interior air temp selector is all the way maxed to cold that some hot water is circulated inside the cab. I can't believe that our AC would let us let in hot water but this is true unless the air temp is maxed to the cool side. I was always using the AC and I thought that if I didn't have the cold air all the way to the max that it wouldn't run the compressor as much. Well I guess I was wrong. I guess the only way to reduce the cold air is turn down the fan. Does this seem right or is the AC somehow closing off the hot water???? I did notice that the air selector when not on the max cold does make a different sound.
Old 04-12-2004, 02:24 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
The only control on the air conditioning is an internal switch that prevents the evaporator (the chiller) from getting so cold it frosts over and stops the air flow. In cool or cold weather this will cause the compressor to run less.
What we have mixing air conditioning and heat is very common. The only car I've had that actually had a thermostat on the airconditioner was my '76 BMW, and the control wasn't very smooth--it usually got automatically too cool before it got automatically too warm.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
