Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 04-29-2004, 06:21 PM
GreyTRD03's Avatar
Dealer : Quality Toyota Scion
2003 Toyota Tundra 4x4 Limited EC
Last Online: 04-08-2009 09:52 PM
GreyTRD03 is on a distinguished road.
GreyTRD03's Photo Albums
Lightbulb Spare Tire Security
My spare tire was stolen last week so I ran a thread in the wheel/tire section which addressed solutions I'm using to prevent a reoccurrence. Thinking this might (or might not) benefit the general Tundra populace, I'm posting it here.
I bought the Toyota spare tire lock which essentially provides a specially keyed male fitting to turn the spare tire lift mechanism while blocking access using the std "hooked" end that we all got in our Tundras. While installing the lock, I noticed it was possible to reach up/over the spare and turn the lift mechanism by hand. This could, of course, defeat the lock mechanism.
To deal with this, I used a 4in piece of 3in square steel tube and secured it around the lift mechanism shaft/lock (see the gallery for pix). It doesn't entirely prevent access to the shaft, but makes it much more difficult to rotate manually. I'm going to eventually fabricate an improved steel tube to cover the entire shaft and probably weld it in. I also welded an old oil filter wrench to the lift plate to block access to the cable end (see pix).
If you look at the pix you can also see a length of cable exposed between the frame down to the lift plate. It might be possible to get a lock cutter in that space and cut the cable, so I plan to fabricate another steel tube to cover the exposed cable.
Overboard? Maybe, but I'm not particularly anxious to spend $200 and another day searching for a spare tire lock, 16x7 steel rim, and same size tire...or worse discovering the spare is gone when you really need it. PS - I also recommend wheel locks. Tis the world we live in...
2003 Tundra 4x4 TRD Limited EC
Daystar 1in front lift, Hellwig Swaybar, Front Window Tint, Weston Wheel-Wheel Stepbar, Auto Dimming Mirror, Line-X Bed(group buy), TRD Dual Exhaust, Bridgestone 265-75R16 Dueler AT Revos, Load C
Old 04-29-2004, 06:44 PM
EZ2BME's Avatar
Last Online: 04-03-2007 02:57 PM
EZ2BME is on a distinguished road.
EZ2BME's Photo Albums
Hey GreyTRD03,
Thanks for sharing that security tip with the rest of us. I bought the wheel locks and spare tire lock, when I bought my Tundra. I didn't think the spare would still be vulnerable to theft, though. You did a great job on that security mod, as I was just checking out your pics. Looks very professional. Sorry to hear you had to go through the grief of finding a replacement. I would've liked to have seen that great looking pooch of yours take a bite out some thief's azz!!
Old 04-29-2004, 08:13 PM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel,
2009 Toyota Matrix Pontiac Vibe
Last Online: 10-20-2009 03:43 PM
file014 may have some regrets.
file014's Photo Albums
Ive got a winchlock. IT was about $25. Seems to be a decent idea for preventing theft, but not foolproof. I dont have a pic, but if you google for winchlock it will probably come up. Its made by Motive Locks.
Old 04-29-2004, 08:40 PM
EZ2BME's Avatar
I just checked it out....Can't believe it....one of the few sites where you can actually find something for a Tundra. Thanks. BTW...this link should take you directly to it, if anyone else wants to look:
http://wheelskin.com/Merchant2/merch...e=Toyota+Locks
Old 04-29-2004, 08:47 PM
Bbbutch's Avatar
2002 Toyota Tundra,
2005 Toyota Highlander Wife's Highlander
Last Online: 10-21-2009 12:12 AM
Bbbutch is on a distinguished road.
Bbbutch's Photo Albums
Here's the one I got. May be a little cheaper.
http://www.accessconnect.com/prod04.htm
Old 04-30-2004, 09:42 AM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 04:03 AM
RichR is on a distinguished road.
RichR's Photo Albums
Default They all look the same.
I had a spare looked under a previous truck with a Winchlock.
The rod was all that they left.
I used a Motorcycle Kryptonite Cable until corrosion and chain lube gummed it up.It worked great until I took a suggestion on lubrication.Now I have a two eyed cable and a weather resistant Master lock.
RichR
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
