Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 05-17-2004, 07:21 PM
taylor's 2001 Tundra's Avatar
Dealer : Bill Dube Toyota
Last Online: 09-20-2006 06:42 PM
taylor's 2001 Tundra may have some regrets.
taylor's 2001 Tundra's Photo Albums
Default headlights
i was checking out my headlights when i was washing my truck when i noticed a film or haze on the inside of my headlight, what works best to clean it up since i dont want to damage it any further. i have a 2001 tundra and my drl's are off.
thanks
2001 SR5 Tundra TRD V8
Thunder Metallic Grey
Bilstein HD yellow/blue, Performance Products 1" Progressive Rate Springs, Linex Under the Rail, Westin Side Step Nerf Bars, K&N Filter, Borla Cat-Back Exhaust RS, Optima Red, Osram Sylvania XV replacement bulbs Headlights and Fogs. DRL Mod. ARB Sahara Bull Bar, KC stainless 150 Watt Daylighters
Old 05-18-2004, 12:30 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 03-01-2010 12:45 AM
Dude Boy may have some regrets.
Dude Boy's Photo Albums
I've noticed the same thing on my 2000. I'm thinking we are just "stuck" with this unless there's a way to go in through the opening for the bulb. I don't think you could do much with that method though. I think I'm just going to have to live with it. Mine looks kind of like "jack frost" on a window; kind of patterns to it or something.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 05-18-2004, 09:13 AM
2003 Toyota Tundra
Last Online: 01-06-2010 12:04 PM
MarkF may have some regrets.
MarkF's Photo Albums
My neighbor just had his headlight assemblies on his car cleaned and polished by a fellow that does it for a side business. He pulled out both assemblies and cleaned the inside with a detergent and rinsed with distilled water and denatured alcohol. Then connected a shopvac to the assembly and blew out/evaporated all the liquid. Next, he wet sanded the outside with very fine paper (like you would use for auto body work) and then used 3-4 different grades of compound polish with a buffer and finished with a wax. They went from cloudy and yellow to clear. It took most of a Saturday morning and I think he paid ~$100.00
If you have a buffer I think there are kits available to DIY online.
Old 05-18-2004, 05:45 PM
shelbix2020's Avatar
Dealer : South Coast Toyota Scion
2002 Toyota Tundra
Last Online: 04-09-2008 10:26 PM
shelbix2020 may have some regrets.
Send a message via AIM to shelbix2020 shelbix2020's Photo Albums
or find some replacement ones on ebay for $35 like I did! ... brand new, off a wrecked Tundra
Originally Posted by HuskerTundra
Shelby is right. Chicks dig purple. Buddy of mine has a PURPLE tundra , and he is always gettin compliments from ladies at school on his truck.
Old 05-18-2004, 08:54 PM
longboard's Avatar
Last Online: 05-06-2005 07:16 PM
longboard may have some regrets.
longboard's Photo Albums
I had the same problem with an 88 mustang years ago, at that time i learned a secret that really worked well - you fill the inside of the headlight cover with some windex mixed with lime away and let it sit for a few minutes - then put a paint brush inside and scrub until your hand feels like it will fall off - rinse well and blow dry with the air hose, presto all clean. For the outside just use a good plastic polish. This worked good on ford plastic! Or the best way just buy new ones.
2003 SR5, A-CAB, V8 2WD. LSD-3.91's, Tow Pkg & TRD Filter.
Old 05-19-2004, 12:22 AM
Agent WD-40's Avatar
Dealer : Fox Toyota of Rochester
Last Online: Yesterday 08:54 PM
Images: 12
Agent WD-40 will become famous soon enough. Agent WD-40 will become famous soon enough. Agent WD-40 will become famous soon enough. Agent WD-40 will become famous soon enough. Agent WD-40 will become famous soon enough. Agent WD-40 will become famous soon enough.
Agent WD-40's Photo Albums
http://www.autopia-carcare.com/bgi-20214.html
Might want to give that a try. Perhaps it will work on the insde of the light to help out in the future.
Old 11-13-2004, 10:50 PM
Dealer : Hank Aaron Toyota
2002 Toyota Tundra
Last Online: 10-11-2006 03:14 PM
Supraman93 may have some regrets.
Supraman93's Photo Albums
This is what I did on my supra when my headlights fogged up. Pretty sure the tundra headlight would be a similiar process polishing headlights. Don't let the fact that you are putting them in the oven scare you. I set the oven for 190*. Just be careful because the seal will be pretty warm. Just polish with the Novus/Plexus or another plastic polish. I used Blue Magic Plastic/Plexiglass polish from Wal-mart and had great results. I had a write up on supraforums but I can't find it anymore.
Ryan
2002 Tundra, SR5, V8, Access Cab, TRD Offroad package, Putco Pop-up locker bed rails, clear side corners, Silverstar headlights and foglights, AVS bug deflector
Old 11-14-2004, 01:30 PM
BraneDead's Avatar
Dealer : Laurel Toyota
2002 Toyota Tundra
Last Online: 12-13-2009 12:28 AM
BraneDead may have some regrets.
BraneDead's Photo Albums
We did the same thing to my buddy's 98 Accord to get the lenses apart pretty much. Actually instead of the oven, we just evenely hit the entire seal with a heat gun, and slowly pried it apart and ventually it came right apart. Make sure you run a new silicon bead though, or else you'll be cleaning them again in another month.
Black '02 Tundra TRD Limited 4wd
315/75r16 Nitto Mud Grapplers - 16x10 Mickey T Classic IIs - Teamwest/Camburg Coilovers - Total Chaos UCAs - Bilstein 5100 rear shocks - PA 3" Body lift - AEM intake - TRD Headers - JBA Y-pipe - Flowmaster American Thunder catback duals - XM Commander - Line-X UTR
My other ride: 2006 Honda CRF 250R
Old 01-20-2005, 08:21 PM
2003 Toyota Tundra
Last Online: 02-27-2008 10:37 AM
Kevin7909 may have some regrets.
Kevin7909's Photo Albums
as for cloudy yellow headlights...my lexus did this and so did my t100(no water inside the lense tho)....believe it or not brake fluid on a towel cleans it extremely well....just be sure to hose the lens off when your done and avoid touching paint with the brake fluid...a friend spilled nitro from his RC car onto his acura TL brake light and stained it...brake fluid took it off in no time...i have done this multiple times and have never had any issues with the plastic/glass lenses on any vehicle....and it's basically free since most of us have brake fluid sitting in our garage anyway....
Kevin
Old 12-07-2006, 10:13 PM
Dealer : Tansky Toyota
2001 Toyota Sequoia Limited
Last Online: 08-19-2007 09:39 PM
BlackLTD may have some regrets.
BlackLTD's Photo Albums
Default Re: Headlight Haze
Wow..that brake fluid trick actually worked. Thanks for the tip. My 2001 Sequoia's headlight were getting kind of cloudy. After the brake fluid, they look pretty good...not brand new, but good enough to consider not replacing them.
2001 Black Sequoia Limited 2WD
Old 12-11-2006, 07:03 PM
Images: 12
I just used a bit of Mothers PowerMetal Aluminum polish on a rag. It took my haze right off. I was quite impressed. No negatives either. It is the stuff they recomend when using the Mothers Power Ball. It is nice too because you don't need to worry about the paint like you do with the brake fluid.
