Where can i find the water control valve that is refered to in the tsb:
AC004-04
AC004-04
Under the hood on the upper center area of the firewall.
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Turn signals are meant to indicate intent not result.
It's black in color with the adjuster cable towards bottom and a heater hose in and out. There's a bunch of steel tubes running across the firewall just below it.
Optima 34R battery
Would anybody have a copy of this TSB???
2002 TOYOTA TUNDRA LTD – 265/75/17 Yokohama Geolander with 17” FJ Cruiser wheels – TRD Dual Cat back – JBA Shorty headers – K&N Dropin Filter – Dastek Unichip Q Series with Flux PDA and custom Dyno Tuned Map - Garmin Nuvi 1690 – Line X Bed Liner – TruXedo Lo Pro QT Soft Roll-Up Tonneau Cover - Luverne 3" mandrell bent Side Steps – Toyota OEM Brake Upgrade (TSB) - PowerSlot Cryo Rotors - Hawk LTS Pads -Smittybuilt Grill Saver - Hella 500 Spot Lights & Clear covers - Tint front side windows - Toyota "Tundra" door sill protectors - Hellwig Rear sway bar - Bilstein 2.5" lift front and Bilstein 1.25" lift Rear
Audio upgrades - Alpine CDA-117 HU, Alpine PDX F4 (100w RMS x 4), Alpine PDX M6 (600w RMS x 1), Alpine RUX- KNOB, Boston S60's front, Boston SC65's Rear, Boston G310-44 Sub woofer, eKo Knu Power and Ground, 6 Channel Monster RCA's all round. (119.4 db)
Future Modifications - Dynamat.
SOLD
Click here for something fun to watch! http://www.youtube.com/watch?v=PqXvQ8X4UJI
2002 Ford Explorer XLT – BabyMobile (Wife’s car) (“,)
