Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 10-04-2004, 05:47 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Default Who's worked with Lexan???
Has anyone worked with Lexan and used it to form around curves? Here's my idea. With all the rock rash I've got on my lower panels, I'm debating on either banging them out and do the whole body repair thing or just cover it with some Lexan. On another note, I'm getting some rock sliders to avoid future lower panel damage. Back to the idea. I want to use the Lexan(1/8" thick) and use a heat gun to form around the curves of the lower part of the doors. Once it's all molded, have it sprayed with Line-X and have it mounted using some small bolts. For now this is just an idea as fund$$$ is somthing I'm currently lacking. Is this possible and how hard is it mold the Lexan?
Mike
http://dyogim.blogspot.com
Old 10-04-2004, 07:11 PM
mandzach's Avatar
mandzach
Dealer : Findlay Toyota Scion
2003 Toyota Tundra,
2007 Toyota Tacoma SILVER-DC-OR-4x4
Last Online: 10-13-2007 12:40 AM
mandzach is on a distinguished road.
mandzach's Photo Albums
im guessing you want lexan because its cheap? (i thought it was not so cheap)
Im sure you might have thought of this but what i would do is take stainless steel plate (maybe even diamond plate) and i would rivet it to your rocker panels with stainless steel rivets (never rust) - that way when they get crushed or hit or ripped you could simply drill out the rivets and replace the panel just like the military does on its H1's. As far as bending them thats out of my area of understanding but i belive the whole rocker section is the same curve so perhaps you could create a Jig to hammer out the plates to the proper curve?
anyways you can find small plates of stainless on ebay or find a local distributor and perhaps you could buy the scraps from a custom plate job.
2007 Tacoma 4x4 DC/SB - Total Chaos UCA's, Donaho Racing CO's, Deaver Springs, 33" Toyo MT's
.................................................. .................................................> Built for Desert Fun!
Need Tranny Mods?--> IPT Valvebody calibration IPT Transmissions
Old 10-04-2004, 07:21 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Lexan isn't cheap. I just thought of Lexan as it came up on reading some stuff on the Pirate 4x4 board. I've thought about stainless or diamond plate. I figured Lexan might be easier to work with as far as molding it to the contours of the truck.
So many ideas and projects but not enough $$$
Mike
Old 10-04-2004, 08:13 PM
Tundrav8yamaha's Avatar
Banned
Images: 100
Default line x
you could also line x the rocker panel's and also add stainless on the quarter panel's just an ideal.
Old 10-04-2004, 09:10 PM
keiphers's Avatar
Dealer : West Ashley Toyota
2002 Toyota Tundra Limited White TRD4x4
Last Online: 11-27-2007 02:19 PM
keiphers is on a distinguished road.
Send a message via AIM to keiphers keiphers's Photo Albums
If you're really worried about rock rash then Line-X or Rhino the rocker's. IMO, any attempt at some other material would be futile. You'd end up having to replace it several times, which in the case of Lexan or treadbrite aluminum would continuously be expensive. But, Lexan is a cool idea. What about integrating some sort of slider like metal tubing into the door itself? That'd be gnarly lookin and uber protective. My $.02.
2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
[in the works]: Skidrow Plates / Snorkel / Custom rear bumper / Ruf RTurbo
Old 10-04-2004, 09:21 PM
matttom's Avatar
Toyota Lifer
Dealer : Atlantic Toyota
2002 Toyota Tundra,
2000 Toyota 4Runner
Last Online: 11-13-2009 05:01 PM
matttom is on a distinguished road.
Send a message via AIM to matttom matttom's Photo Albums
Default Lexan bending
I've done some work with Lexan and as others mentioned it might not be what you are looking for. For one the material is not cheap, last time I bought some I paid 220$ for a 4'x4' sheet. As to bending it with heat I have found it can be tempermental. If you give it too much heat it will bubble and get weak. You also can burn it when it gets hot. I found you have to get to just the right temp to get it to bend.
I think some of the others here can come up with better ideas, Good Luck
2002 SR5 AccessCab 4x4 TRD
Performance: Borla cat-back, K&N FIPK, Magnetic oil plug, 265/75/16 BFG AT, 16" Rage wheels, Tow package,TRD AAL
Appearance: Molly IS Grille, Sportmaster Tonnau, Clear corner and tail lights, IS mirror covers, Color keyed tailgate handle, Debadged, Window tint, VIN etched glass, Bugdeflector, Ventshades, Stepsheilds,Window Latch upgrade
System: Sony headunit,Sirius s50, 200w Kenwood amp, 10" Bazooka, Sony 10-disc, Infinity 6.5" speakers.
Still sitting in my basement:New IS bumper, Cornfed spacers
2000 4RunnerSR5 4x4, Pro Comp stainless step bars, TRD drop in, Ventvisors and deflector.
2006 Kegerator stocked with Blue Moon Belgian White
New York Mets 2007 The greatest choke job in MLB history!!!!
New York Mets 2008 Blew it again!
New York Mets 2009 They need obamacare
Old 10-04-2004, 10:53 PM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel,
2009 Toyota Matrix Pontiac Vibe
Last Online: 10-20-2009 03:43 PM
file014 may have some regrets.
file014's Photo Albums
Ive edged polycarbonate into lenses for glasses. I think you're just better off getting it line-xed or buy an old beater taco or chevy for an offroader.
Old 10-04-2004, 11:01 PM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
Last Online: 11-03-2009 08:17 AM
Images: 8
sequoiasoon is on a distinguished road.
sequoiasoon's Photo Albums
Are you looking for it as metal protection or to keep paint from chipping? The sprayed on Line-x would probably be the easiest to form to the curve. If you want to protect the paint either the 3m paint film or for more abuse the thicker headlight film.
Old 10-05-2004, 11:50 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
My main reason to use the Lexan is to cover up the rock rash that's already there. Then Line-X the Lexan. I think diamond plate is looking to be the better route and then line-x the diamond plate.
Thanks for all the info and input.
Mike
Old 10-05-2004, 12:06 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Maybe in the future, I would like to get a first gen toy or a late 60's fj40. For now, my tundra will be my trail rig and daily driver.
Mike
Old 10-05-2004, 05:00 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Last Online: 05-04-2009 09:43 AM
Mike Donofrio is on a distinguished road.
Mike Donofrio's Photo Albums
Mike, I worked with Lexan quite a bit in the 90's for lizard cages and the like. AFAIK Lexan is the most durable substance known to man...With the right heat it can be molded (although this weakens the material) Steam will generally turn it white, but a quick dip in boiling water will generally allowe it to be bent somewhat without deforming. Most times you wind up witha crease and weaker material. And at over $100 for a 4 x 8 sheet, it's not cheap to learn on. But it can be drilled, cut with a recip saw and is generally resistant to mechnical wear. There are a few companies that I know back in NJ who can aquaform Lexan to do curves and the like for fish tanks, but these are generally expensive. I used to bug them for scrap for project work and they almost always stuff that I could use. In your case a botched, curved corner, Lexan tank could use a few useful pieces. Start with TAP Plastics ( in the phone book and start hunting for Lexan dealers/fabricators. I would think Rockrails would be cheaper, but I would KILL for some Lexan body panels.
Mike D
Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/LockRightInstall.pdf
2000 Tundra with 175,000 miles and still going!
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
Old 10-05-2004, 05:18 PM
peid's Avatar
Dealer : Billion Motors
1996 Toyota T100
Last Online: 01-05-2009 08:49 AM
Images: 31
peid is on a distinguished road.
peid's Photo Albums
How big of chips and dings are we talking?
If it were my truck I would have it fixed and repainted, then have the clear film, Clear Shield, applied.
I have it on my Camry and it is the best thing. It will be on all my cars from now on and in even more areas after seeing how well it holds up and hides/blends in and barely noticeable.
I would think you could have those pounded out and repainted in the $250 range, then spend another $150 on the clear film. $400 total. I will bet you will easily spend that on diamond plate plus Line-X.
1996 T100, 180,000 and counting
Old 10-05-2004, 05:20 PM
Mike, what about DIY Bondo and then just Line-X the whole enchilada. Did you know that Line-X is bomb proof?
Just brainstorming..
Mike D
Old 10-05-2004, 06:15 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Here's a pic of the driver door: Driver door
And here's a pic of the pass door:Pass door
Mike
Old 10-05-2004, 06:19 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
I've thought about that but, I don't want to have to worry about smoothing it out. I'd rather straighten the driver side door crease and then cover it. As well as just cover the pass door. I'm thinking maybe covering up the door up to the moldings. Thanks for the info!
Mike
