Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 05-07-2002, 08:00 PM
Dealer : Hamer Toyota
1995 Toyota 4Runner LE,
- Other - 07 Eclipse GS
Last Online: 12-05-2008 01:24 AM
2DaMax is on a distinguished road.
Send a message via AIM to 2DaMax Send a message via Yahoo to 2DaMax 2DaMax's Photo Albums
Default Broken Rear Window Latch!
I went to the dealer today and ordered another pair of rear window latches. One already broke misteriously and the other has a small crack in it that is probably going to get worse very quickly and break off.
Anyone else had this experience, aside from Leathernuts (different circumstances)? The parts guy told me that they've been getting alot of people with the same problem and that the new latch was made by a tougher material. However, its not covered under warranty (not even extended warranty) according to the service writer.
The part cost $30, which I'm not going to complain about because a broken latch only makes my vehicle more vulnerable to theft. But if anyone can shed some light on the warranty issue, I'd appreciate it. They also gave me an 800# to call to determine warranty coverage on this particular item which I'm going to call tomorrow.
-Dennis
-Dennis
Old 05-07-2002, 08:20 PM
ausk9-0's Avatar
Dealer : Kaimuki Toyota
Last Online: 09-30-2008 02:38 AM
ausk9-0 is on a distinguished road.
ausk9-0's Photo Albums
Default 3yr/36,000
I had mine replaced by the 3yr/36,000 mile warranty. If I were
you I would especially since I never used mine more than 10
times.
Old 05-07-2002, 09:11 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 11-14-2009 08:18 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
One of mine did, but it still stays shut so I haven't bothered to take it in yet. Hate to take the truck to the dealership when the only problem in 1 yr and 2 months and 22,000 miles has been a broken window latch. But I bet this thing had only been opened about 3 times before it broke. I would think this should be covered under the 3/36 warranty though.
SATundra
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 05-07-2002, 09:41 PM
Last Online: 07-02-2008 12:00 AM
Overlord2000 is on a distinguished road.
Overlord2000's Photo Albums
Default Warranty for rr window latch
Depends on which warranty what level, etc. yada yada.
If it was OE warranty (i.e. 3/36) it would be covered. Mine was.
For extended warranty, you may be told this is a trim or switch, which often are not covered. Just focus on what the part name- window latch, and a latch is a mechanical fastening device.Most extended warranties are merely mechanical failure insurance. So if they give you a hard time, check your fine print and good luck.
Old 05-10-2002, 08:37 AM
Last Online: 04-23-2008 09:08 AM
nightstick is on a distinguished road.
nightstick's Photo Albums
yep,
Same thing hapened to me. I also used the latch maybe 8 times. They DID cover it under warranty. no questions asked..
Old 05-10-2002, 10:45 AM
Last Online: 09-18-2003 03:23 PM
UtahTundra is on a distinguished road.
UtahTundra's Photo Albums
Default 2000MY problem?
I wonder if this is mostly a problem with the 2000 model year vehicles? It seems that most of the previous posts, the writers experiencing the problem had 2000 tundras. Maybe they switched to a tougher plastic near the beginning of the 2001MY?
My Tundra is a 2001 and the latch hasn't broken and is used extensively. I have a 7 year-old daughter who is fascinated by it. She opens and closes it at least 5 times everytime she sits in the backseat on trips around town. I couldn't begin to count the total number of times it has been used but it would be well into the hundreds!
Good luck on getting it fixed. It seems like an obvious warranty fix -- don't let the service writer tell you different!!
Old 12-10-2004, 11:26 AM
Last Online: 12-10-2004 11:32 AM
JrFrench is on a distinguished road.
JrFrench's Photo Albums
Unhappy
I have had my 2000 Tundra for 5 years and I just recently discovered that both my rear window latches are broken. The plastic clip that holds the pin broke in half on both assemblies. The windows have rarely been open since owning the vehicle. It appears that this has been a common problem with the Tundra, based on what I have read on the internet.
I am going to talk to the dealer and see if it would be worth contacting Toyota. I doubt it will, since the truck is out of warranty, but I at least want to be heard. They really don't care much once the vehicle is out of warranty. So much for Toyota quality and service.
I love the way the Tundra engine runs and performs, but I have had numerous problems with this vehicle - brake problems, multiple oxygen sensors go bad, broken window latches, dash lights failing - all this before 50,000 miles. My confidence in Toyota quality is not very high and I will probably never buy another Toyota again. I'll buy a Ford or a Nissan truck next time.
Old 12-10-2004, 12:28 PM
ausk9-0's Avatar
I've had everything you've had with the exception of the dash lights failing. Still, I would never go Ford or Nissan.
Old 12-10-2004, 02:40 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 02:16 PM
nhparrot's Photo Albums
There was a TSB on the latches - BO029-01
~Glenn
Old 12-13-2004, 08:07 PM
Last Online: 01-17-2005 12:12 PM
SouthPark is on a distinguished road.
SouthPark's Photo Albums
Default rear vent latches
The window latch problem is a manufacturer design defect. They used plastic and the plastic is brittle. I have had two Tundras, a 2000 and a 2002, and both have broken latches. I've seen others with it too.
I have found that silicone spray helps lube the latch, but it's not a cure, just a help. At least the replacement part is not expensive.
Old 07-08-2005, 02:07 PM
Last Online: 04-18-2008 03:12 PM
rv8av8r is on a distinguished road.
rv8av8r's Photo Albums
Wink Quarter Window Latches
Both my 2000 Tundra latches failed when I open the windows for probably the first time in five years. The dealer said no warrenty and $108 EACH, installed. What a freakin' deal!!
Anyway, I found then for < $20 at
https://www.1sttoyotaparts.com/
Old 07-28-2005, 06:38 AM
Last Online: 09-22-2009 12:52 AM
Joon is on a distinguished road.
Joon's Photo Albums
.. mine just broke.. the local dealer quoted me ~$30 for the replacement part.. $130 for the labor.. that's per each side..
does anyone have DIY guide to replacing the window latch?
Old 08-04-2005, 03:58 PM
Dealer : Champion Toyota Scion of Austin
Last Online: 12-12-2008 06:38 PM
rvanderwerf is on a distinguished road.
rvanderwerf's Photo Albums
Default part #?
Anyone have the part # on them? One of mine is broken, and the other is about to go. Can't you just replace the plastic center part that breaks but knocking out the pins on the ends?
Ryan
Old 08-04-2005, 04:47 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Ryan
No. Toyota doesn't sell it by pieces like that. You have to purchase a complete latch.
Part number is 62910-34011-##. The last two is dependent on which side RH or LH.
Mike
http://dyogim.blogspot.com
Old 08-04-2005, 09:46 PM
Dealer : Freedom Toyota
2001 Lexus LX470,
Last Online: 05-07-2009 01:26 PM
tundra61 is on a distinguished road.
tundra61's Photo Albums
Does anyone know how to replace the assembly? Mine recently broke and it looks like the door panel needs to be removed to replace them. Is this correct?
