Motorcycle carrier and cap
If you mounted a 2" hitch receiver on the rear of the trailer, you can use a hitch mounted motorcycle carrier. If you do go this route, I would suggest getting one with an upright support. This stabilizes the motorcycle's movement when accelerating and braking. I use one on my Tundra to carry my KTM RXC 620. Its a little bit of a challenge to get it on the carrier, because it is fairly high up. On a trailer the carrier would be lower and more managable.
It would be a significant challenge getting a motorcycle in the bed of a truck with a cap on it. Especially a bike as heavy as yours.
As far as caps go. I like the Snugtop for the Tundra. The side screens slide out so you can access the bed from the side windows, but still have the screen option. Also the front window folds down so the exterior sides of the windows between the cab and cap can be cleaned easily. The latch security is quite robust and the ability to lock yourself in the cab but also unlock from the inside was a good feature. Price seems high, but when comparing the standard Snugtop to a Leer with the options to get it to Snugtop level, the prices are comparable.
