Creaking Dash
After finally getting enough spray lube behind the Tundra's dash at the firewall and windshield, it is now quiet. An easier way for sure is to have your windshield replaced. Had the Sequoia's glass replaced and when out, all of the dash board plastic tabs and grommets are all visible and easy to lube. Remember this when replacing the windshield - lube the dash's tabs when the glass is removed. It will fix and/or prevent the noisy dash. If you don't have the problem, you probably will develop it at somepoint.
