Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 02-21-2005, 04:54 PM
Last Online: 02-22-2005 02:41 PM
kwanjangnihm may have some regrets.
kwanjangnihm's Photo Albums
Default 04 DC A\C Smells???
I have an 04 Tundra DC with 9000 miles. Usually once or twice a day it will emit a funky odor from the a\c vents. Contacted a service rep today who said it may be a buildup of bacteria\mold. He stated they have a method of disolving this and flushing the system. Anyone else experiencing this problem?
Jeff in Florida
Old 02-21-2005, 04:58 PM
stewairball's Avatar
Dealer : Mossy Toyota Scion
2004 Toyota Tundra
Last Online: 11-07-2005 11:08 PM
stewairball may have some regrets.
stewairball's Photo Albums
Default me too!
I actually have the same issue. It happens when I turn the A/C off and leave the fan running after the fact. I can't imagine that it has to do with mold or bacteria. Keep this post going with any info that you find out from your dealer. I would love to fix it or least find an answer.
Old 02-21-2005, 05:32 PM
Tundranized's Avatar
Dealer : Earnhardt Toyota
Last Online: 02-27-2006 02:58 PM
Tundranized may have some regrets.
Tundranized's Photo Albums
Yes, this does have something to do with a mold/bacteria buildup, lots of cars have this problem, my 00 Tundra, 00 Ford Zx2, 90 Crown Vic. The trick is to run the fan with the switch set on fresh air, not recirc, for a couple minutes before you shut the truck off. If you dont want to do this then you need to take some Lysol or other type of disenfectant and spray it into the cowl vent with the fresh air on so that it draws it into the system to kill the mold. We have it happen often out here in AZ.
Brian
2000 Tundra 4x4 (Gone and forgotten)
Old 02-22-2005, 10:01 AM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: 03-01-2010 11:11 AM
Images: 11
dsrtrcr01 is a splendid one to behold. dsrtrcr01 is a splendid one to behold. dsrtrcr01 is a splendid one to behold. dsrtrcr01 is a splendid one to behold. dsrtrcr01 is a splendid one to behold. dsrtrcr01 is a splendid one to behold. dsrtrcr01 is a splendid one to behold. dsrtrcr01 is a splendid one to behold. dsrtrcr01 is a splendid one to behold.
dsrtrcr01's Photo Albums
Thumbs down Mold
I agree. Make sure you run it on fresh air before you park it to help dry out the system. I used Lysol anti bacterial to disinfect mine and it worked well. Just put it on fresh air with the fan on High and spray in the grates in front of your windshield.
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 02-22-2005, 10:10 AM
Sumo99's Avatar
Dealer : Carson Toyota Scion
Last Online: 01-11-2010 11:06 AM
Sumo99 may have some regrets.
Sumo99's Photo Albums
Fresh air...and turn off the A/C
'01 Color-Keyed Limited Tundra TRD 4x4
JBA Headers, TRD Exhaust, IS Grill, IS Bilsteins, Hellwig Sway Bar, AR-23 wheels w/ 265/75 Yokohama AT's, SnugTop XV Shell, BedRug, Yakima Rack
Old 02-22-2005, 01:03 PM
ALL MOTA's Avatar
Dealer : Frontier Toyota
Last Online: 02-20-2010 11:46 AM
ALL MOTA may have some regrets.
ALL MOTA's Photo Albums
I was thinking about using Lysol too, but I was worried it would cause discoloration with the black plastic vent grill. Before I do it, will Lysol cause discoloration???? I was going to try to swap the can tips with something that has a tube, but if it's safe for the black plastic, then I just blast it thru.
Old 02-22-2005, 01:39 PM
dsrtrcr01's Avatar
Images: 11
Talking ????
I used the tube and tip from another spray can so I do not know about the discoloration but I would use the tube because I was able to spray in the exact location I wanted and not just thru the grate.
