I now that latch fix is sorta "rigged" but I am impressed enough to give it a try when my other one breaks. I wonder if we could get this into the "How-To" section somehow?
Mitch
PM one of the Mods to ask them. It should go in the "How To" area.
I posted a picture of my fix at: http://www.geocities.com/sawyerkt/latch.jpg
It seems to work with no problems opening and closing. I don't know if this is a long term solution but if one of the tie straps brakes it will take about two minutes to fix it again. I guess this fix would depend on where your latch broke.
I couldn't figure out how you "fixed" it with zip ties. Then I saw the picture. Very impressive!! That is a great case of serious ingenuity!!! When closed I bet you can’t even tell its fixed with ties. Definitely needs to be put in the “how to” area. Even for those who want to fix it with new parts – this is a great quick fix till you can get to the dealer.
Good job,
TIM
Black 2000 4X4 Access SR5. 2-1/2 DayStar front, 1.5 AAL Rear, Diff Drop, Limit Strap, Foglight, power-outlet and map light mods. Tailgate open LED, power tailgate lock, Disconected buzzer, Hellwig sway-bar and Powertrax No-Slip Locker.
Re: Broken window latch in Access Cab Tundra, DIY fix?
Originally Posted by mitchr
I just replaced the little plastic part that broke. I just pushed out the pins holding in in place and done the same with the new part then reversed the process. I saw really no need to have to pull the door trim off when there wasn't any thing wrong with those parts. Just my .02.
Mitch
Anyone know where to get the plastic clip mentioned above? Is there a part # or do I need to hit the local bone yards?
You have to buy the whole assembly. I just cut corners and only used the plastic part that broke instead of having to deal with taking the door panel off. I found one on ebay.
Make em out of metal, then they never break! I did.
Like many of you I had both my original latches replaced under warranty despite the fact that I rarely opened those windows, becase the cheap plastic link cracked, and the replacement links started cracking in the same place a year later.
I am very disappointed to learn that they haven't improved the parts, and that they only sell them as part of a very expensive latch assemble. Shame on Toyota.
Not about to spend the money for new ones, I got some small pieces of aluminum and made a pair of replacement ones that should never break. I used the broken ones as a guide and used a die grinder with a carbide bit to do the final shaping. They look and work just like the original ones, and only look different becase I left them bright aluminum instead of painting them black.
Final cost to me, about 1/2 hour of my time, and $0.50 cents worth of aluminum.
Reason: Add a picture of a metal replacment link
Re: Make em out of metal, then they never break! I did.
Originally Posted by tundraboy27909
Wow that is almost as good as my zip tie idea!
I kind of hope my metal links last a bit longer than your zip tie solution, and are a little more secure. If I was on the road without a drill and a file, I wouldn't hesitate to use Zip Ties, but not when I'm at home and have the time to do something more permanent.
Originally Posted by Agent WD-40
My drivers side access window latch broke today when I closed it. The other side broke when the truck was new and was replaced under warranty. I know there is a TSB for it.
I was wondering if I could just order the new and improved TSB parts myself and do my own fix. It isn't worth it to leave it at the dealer for just a window latch. Is this an easy fix? Anybody else tried? Is this sort of thing covered under the Extended Platnium Warranty from Toyota? Thanks for the help.
Check out this new link:Access cab window latches
It looks like we have a TS member/machinist who is going to fab up a bunch of the latch parts in metal (aluminum I assume).
No idea what our cost will be yet.
In the mean time, I've done the zip-tie fix.
'00 Thunder Gray Ltd 4wd TRD Oak Leather Interior
Roll & Lock Tonneau
All LED's Inside and Out
'05 DC center console installed
Map Light Mod
Pwr Outlet Mod
Ignition Chime Override Mod
Arm Rest Mod
Dual Magellan GPS's
ScanGauge II
Hurricanes Ivan and Dennis Survivor
Bill and Scooter say: "Tundras' Rock!"
Nothing like going down the road with your access cab rear windows rattling. Both of my access cab rear window latches broke. I am not sure if the break is the same as the one everyone else is describing or not. The tips of the plastic latch broke on mine. I fixed it by using some small tie straps. I tied one strap around the plastic latch and the metal pin to hold what was left of the latch on the pin and then tied another around the middle of the latch to hold the other tie strap in place. It was really a cheap fix and took all of two minutes to do. Let me know if I need to post pics.
Genius, pure bloody genius! Thanks, I owe you a beer for each of the two latches I was going to replace!
Thank GOD i found this thread. My sisters rear latch on her Tundra was damaged after an attempted break-in to her truck. LUckly nothing was stolen but we were stuck with a $200 plus repair from our Local Toyota Dealer.
Now my latch snapped on me completely on my rear access window on the driver side. Completely caught me off guard and thought it was a fluke that it happened. Though now it seems that its almost a common failure in the Tundra. Initially i was worried that it would run me a few hundred dollars to fix it at the dealer.
So i take it the average price for replacement parts would run about $35 from a Toyota dealership? Might as well make it a do-it yourself project since some of ya only spent a few minutes to replace it.
2003 White Tundra Sr5 v8
-stock for now.
Or you could get into the group buy and get these! Zip ties keep your window from flying open but wont keep a burglar out.
Check my sig
Go to JSIMotorSports.com for billet window hinges. NOW IN STOCK AND READY TO SHIP
