This is a discussion thread titled "AC Condenser", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Here's my dilema. Got a hole in my ac condenser. Unknown how. Replaced it with a new one. What is the next step I should take. SHould I pay to have the system evacuated and filled? Or can I just fill it with the one line in type refill kits?
Dan
You definitely need to have it evacuated to get any air and moisture out of the closed system. If you do not it will run very high pressures (especially with R134A) and not work properly. The higher pressure could damage your compressor and result in much higher costs. Better to have a professional with the proper equipment to the work. A layman can add refrigerant in a pinch to top off a charge but only if the charging hoses are purged of air and other non-condensibles so they're not induced into the closed cooling system.
I did industrial/commercial refrigeration for a living some years back so I'm familiar with a/c systems.
Larry
2004 Tundra V8 Limited Access Cab 4X4, Michelin 265/65/R17 ATX2 tires, Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Larry
Couldn't have said it better myself.
23 yrs with TOYOTA
Yeah... so I had to have my AC condenser replaced today because there was a hole in it... not too cool.
Armada 176 AR5s Skis, Look P12 Jib Bindings, Rossignol Bandit B1 Boots, Scott Poles... in the bed of a 2000 V8 Tundra 2x4 Access Cab with:
JBA Titanium Coated Headers, Stone Mountain Racing Y-Pipe, Flowmaster 50 Exhuast, Teamwest Sway-A-Way Coilovers, Camburg Upper Control Arms, Wheeler's Add-A-Leafs, AEM Brute Force Intake, MB Quarts, US Acoustics Amp, Bazooka Tube, Lots of Dynamat, A.R.E. LSII Tonneau Cover, Sir Michaels Rollpan, Bushwacker Flares, Shaved BSM, Billet Grilles, Mickey Thompson Classic Locks, 305/70/16 Pro-Comp X-Terrains, Lots of little things here and there. Future Projects: Color-Coded White Rear Bumper and Tailgate handle, Revalve SAWs, Deaver 11 Leaf Packs, Bilstein 5100 Rear Shocks.
All this info repeated here!
