Any one else notice wet carpets on new 05 DC
I have a 05 DC and have noticed after it rains or I wash the truck, when you open the rear doors alot of water spashes out from the bottom seal and the carpet is wet a good 2-3 inches in from the edge of the door seal plate. I took it to the dealer and he said he has done a "few" of them under warranty saying he has to pull off the inside trim and put in the water moister barrier. It seems to me that the problem is that it is not allowing water to drain out of the bottom of the door or it is but its draining and the seal is so tight it holds the water in. Anyone else have or seen this problem.?
