Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 04-27-2005, 07:56 PM
blazze2005's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2005 Toyota Tacoma
Last Online: 11-14-2009 03:02 PM
blazze2005 is on a distinguished road.
Send a message via Yahoo to blazze2005 blazze2005's Photo Albums
Default Center Console Removal Please Help!
Anyone know how to remove the shifter handle on an automatic 05 tacoma and also how to remove center console? Thanks for any Help!
Old 04-28-2005, 01:07 AM
2005 Scion xB
Last Online: 12-02-2005 01:22 AM
nicoj1222 is on a distinguished road.
nicoj1222's Photo Albums
the shifter just unscrews. for removing the center console you first pop off the metallic trim that sorrounds the shifter. pull upwards firmly and it pops off. then you will see four screws there, remove all four. then pop out the cupholder by pulling up on it. remove the tray that sits to the right of the steering wheel under the a/c vent, to do this just pull firmly. to remove the front half of the center console you pull UP and torwards the rear. the up part is important, you will see a seam where the center storage half meets the front half. what holds them together besides the 4 screws you removed is plastic hooks. these are shaped like a horizontal j and will release as you lift the console. in front there are also tabs that release when you pull rearwards.
if you need anythign else ill try and help. i have some pics of the removal as well
Old 05-01-2005, 03:15 PM
blazze2005's Avatar
2005 Toyota Tacoma
Default Thanks!
Thanks! Came out pretty easy...
Old 05-26-2005, 02:25 PM
Last Online: 03-06-2008 02:19 PM
jlnguyen27 is on a distinguished road.
jlnguyen27's Photo Albums
Default Console removal
Can you please post some pics for the 05 tacoma console removal? thanks.
HOW TO: Install a '03 Tundra, Center Console in an '01 atomic80 Member Mods 1 12-18-2005 12:34 PM
TACOMA: 05 DC Auto Center Console Removal j4x4ar3 Interior & Exterior 3 04-25-2005 06:46 AM
04 Tundra DC Center Console Removal Tips??? Lexus Luthor Interior & Exterior 3 03-24-2005 12:36 PM
2005 Tacoma In-Cab power Outlet sbessel Member Mods 0 03-22-2005 10:00 PM
Tundra - Center Console Removal tundraofalpha Interior & Exterior 4 09-23-2004 02:13 PM
