This is a discussion thread titled "foldacover", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-04-2005, 03:48 PM
TRDVTX's Avatar
Dealer : Robbins Toyota
2003 Toyota Tundra
Last Online: 02-07-2006 05:34 AM
TRDVTX is on a distinguished road.
TRDVTX's Photo Albums
Default foldacover
Does anyone have Foldacover on a Tundra AC? I am thinking about buying one.
2003 4wd AC V8
Old 05-04-2005, 10:48 PM
jim63dt's Avatar
Dealer : Staten Island Toyota
Last Online: 04-05-2007 10:54 PM
jim63dt is on a distinguished road.
Send a message via AIM to jim63dt jim63dt's Photo Albums
[quote=TRDVTX]Does anyone have Foldacover on a Tundra AC? I am thinking about buying one.
Ive been looking for a decent tonneau at a good price. How much could you get this for??
2000 TUNDRA SR5 4X4 ACCESS CAB, LUND WINSHIELD VISOR, FRONT AND REAR VENTVISORS, CROME BED RAILS, CROME STEP BARS, DROP IN BEDLINER, LOW PROFILE TONNEAU, WHEELERS COILS ON IVAN STEWART BILSTIENS, FLOWMASTER SERIES 40 SINGLE IN DUAL OUT WITH SLANT TIP PIPES, DEBADGED, MAP LIGHT MOD, BACK SEAT MOD
Old 05-05-2005, 07:25 AM
TRDVTX's Avatar
2003 Toyota Tundra
[quote=jim63dt]
Truckaddons.com has them for $565. Here's the link:
http://www.truckaddons.com/Catalog/s...foldacover.htm
Old 05-05-2005, 09:56 PM
triggs75's Avatar
Dealer : Claremont Toyota Scion
2004 Toyota Tundra
Last Online: 06-30-2008 06:17 PM
triggs75 is on a distinguished road.
triggs75's Photo Albums
I have the advance cover and think its great. there's a couple write up's on them already that a few of us have replied on. Just search under advance cover. I would get it again.
Chad
2004 V8 TRD Offroad package SR5 4x2 Access Cab
STEREO MODS: Pioneer 8600 headunit | jl 250/1 amp | Alpine 320/2 amp | kicker 65/2 door speakers | 2x 8" punch 2's in Q-Logic box under seat | XM pioneer gex-910 radio tuner | Harmon Kardon Plug and Play | Street wires set up | & dynamat
Exterior Add-ons:2.5" King Coilovers | 4.5" TC Lift | Bilstein 5100 Rear shocks | AAL Rear | 4" rear block | 315/70/17 BFG AT's | 17x9" Boze Fatal's 3 5/8" B.S. | Custom steering shaft | Extended driveshaft | JBA Headers | Mangnaflow 14" muffler | Front Grille | Advance Cover | Bed Mat | Challenger Running boards | Window Tints | Debadged | AMI Antenna | Temp & Comp. rear view mirror | TRD oil & Radiotor caps | Clear Corners | X51 Fatboy Bulbs & IPF Wiring Harness | Backup Sensors
Recently Added:ARB Airlocker with 4.56 gears.
Old 05-05-2005, 11:22 PM
keninsb's Avatar
Dealer : Toyota of Santa Barbara
2002 Toyota Tundra,
1996 Toyota Camry LE White Tan Leather
Last Online: 12-07-2008 03:40 PM
keninsb is on a distinguished road.
keninsb's Photo Albums
Ditto Triggs75 remarks. I have the advance cover. I have had it for a couple of years and the only problem I have had has been a couple of small water leaks. One leak was from installing the seal on top of Linex (which does NOT make a good seal). The other was from a seal that had started to come loose. A call to Advancecover and they sent me all of the parts I needed for free.
Do a search (if the stupid search engine is working yet) and you will find a lot of info on old threads.
A couple of tips if you do get one:
1) I used screws to mount the mounts directly to the bed instead of the "C" clamp devices that come with the cover. You will find there is less need for occasional adjustment, and a couple of the clamps don't work so great at the rear end of the bed.
2) The cover boasts two 10mm (or 3/8") bolts that hold the cover in. Just remove the bolts, and the cover pulls right off. I drilled out the mount were these bolts are and used two locking pins (the kind with a spring loaded ball bearing in them). That way you don't have to have any tools to remove the cover, and it is just as secure because access is UNDER the cover.
Hope this helps.
Ken
To many mods to list...
Bookmarks
Similar Threads for: foldacover
Preferred Bed Cover? Bryon Truck Bed Tonneau Covers 90 10-23-2006 04:58 PM
