Side Moulding Idea
+ Reply to Thread
Results 1 to 3 of 3
Thread: Side Moulding Idea
  1. #1
    Junior Member Parshal is on a distinguished road.
    Join Date
    Mar 2002
    Location
    Parker, Colorado
    Posts
    234
    Liked
    0 times
    Rep Power
    12
    Default Side Moulding Idea
    I've been reading here about removing the side moulding and having holes to deal with. How many are there? Are they the same size (and astromical number) as the bed rail caps?
    I'm thinking seriously about pulling the side mouldings off and filling the holes and having the rocker panels covered in Line-X all the way up to and including the holes. My only concerns at the is point are dealing with door dings from other people in parking lots (those mouldings do stop them) and how many holes I'm going to have to fill when I take off the moulding. I'm also toying with the idea of having Line-X door edges sprayed on.
    The Line-X dealer I spoke with said that you can't use bondo to cover the holes because the inside of the door gets wet and the bondo will absorb moisture. Now, I'm curious how many holes there really are behind those things.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Fellow Tundra Owner RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch's Avatar
    Join Date
    Aug 2002
    Location
    Santa Clarita
    Posts
    1,720
    Liked
    19 times
    Images
    2
    Rep Power
    1068
    I'm not sure how many holes there are but you would need to braze them up.
  4. #3
    Join Date
    Mar 2002
    Location
    Parker, Colorado
    Posts
    234
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    I talked to a second Line-X dealer who's done a few trucks for me. He said they have a slow-set product that they fill holes will and spray the normal liner over it. He said they do it all the time but their prices start at $700 for rocker panels.
  1. Anyone ever re-do the gas filler to the other side?
    By TheGryme in forum Interior & Exterior
    Last Post: 06-25-2006, 09:43 PM
  2. Side to Side vibration
    By cuball in forum Suspension & Axle
    Last Post: 08-06-2004, 02:43 AM
  3. more header install notes (s&s)
    By DevinSixtySeven in forum Engine & Drivetrain
    Last Post: 06-21-2004, 08:55 AM
  4. Side by side: Stock vs. Cornfed
    By darth tundra in forum Suspension & Axle
    Last Post: 04-23-2004, 05:42 AM
  5. Question about fender flare moulding
    By brandonbjp in forum Interior & Exterior
    Last Post: 04-22-2004, 11:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
