This is a discussion thread titled "Hood Shields / Bug Deflectors (Sequoia)", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
  #31 (permalink)
Old 02-08-2005, 01:47 PM
2003 Toyota Tundra
Last Online: 02-27-2008 11:37 AM
Kevin7909 is on a distinguished road.
Kevin7909's Photo Albums
u misunderstand...i have a T3 with that bugshield....it looks the same...
Kevin
Originally Posted by TUNDRAV8GEORGIA
I know peid (moderator ) but that is not a t3 tundra the t3 was made in 2003 and this picture is a trd ivan edition that is black..I know my tundra's model and year's very well and that truck is not a t3 edition..
hear's a picture of mike's T3 note the difference in bumper has the 03 style with that new t3 special edition grill .How You can tell the model year's on tundra is easy the 03 up model year has the grill going all the way to the hood where as the 00 to 02 tundra have a filler strip or as i called it a velance strip on the bottom of the grill all the way...
http://www.tundrasolutions.com/photo...cat/500/page/1
  #32 (permalink)
Old 02-08-2005, 02:03 PM
Tundrav8yamaha's Avatar
Major Contributor
Dealer : Mike Calvert Toyota Scion
- Other - yamaha,
2000 Toyota Tundra (totalled),
2004 Toyota Tundra Trd Off road Navi,
2008 Toyota Highlander HV limited navi 4wd i
Last Online: Today 08:42 PM
Default it's cool
This picture show's what i am aiming to do...00 to 03 update however i am kepting my bumper hate the plastic setup....
T3 Grill, Line X extra front Bumper coating (too many mod's to list)
www.tundraheadquarters.com (Surporter)
  #33 (permalink)
Old 02-08-2005, 03:08 PM
2003 Toyota Tundra
yeah i know u hate the plastic bumper ...the bugshield that peid uses will look great on with that grill if u wish i will get a pic of the T3 for u to show u its basically identical to the trucks i linked u to....
Kevin
  #34 (permalink)
Old 02-08-2005, 03:58 PM
Major Contributor
- Other - yamaha,
Kevin
kevin can you post me a picture of the bumper peice showing the the front end of the truck bumper with the hood open showing the trans cooler and near the headlight's I am too lazy to drive in the rain and head to Cobb Toyota
  #35 (permalink)
Old 02-08-2005, 04:05 PM
2003 Toyota Tundra
will try and get some to u tonight...no promises but i believe its doable...
Kevin
  #36 (permalink)
Old 02-09-2005, 03:07 PM
2004 Toyota Sequoia
Last Online: 01-01-2009 11:42 PM
vermacelli is on a distinguished road.
vermacelli's Photo Albums
Originally Posted by REDEYE6
Ok guys here we go I nstalled an AVS Auto VentShield bug shield last weekend took a total of less than 90 minutes. I'll scan in the directions and model number when I get back to the house. these steps are from memory
1- remove the hood latch release and hood latch (10mm socket)
2- remove center grill from hood (6 bolts total) you may need penetrating oil. and set grill aside.
3- clean area (center grill hood lip) with mild soap and water dry and prep area with alcohol wipes.
4- prep center area of bug shield with alcohol wipes and afix double sided 3m tape.
5. center bugshield on hood and afix to the hoods lip where the grill mounts with tape.
6- replace center grill, and attach ends of bugshield to the under side of hood with included self taping screw and rubber groment.
the bug shield is very secure and it has a 1+" clearance for the hood.
I'll post photos and instructions soon
I have the same one, $55 from PepBoys if I remember correctly. Goes on really easy w/out screws but I put a couple on the ends under the hood just in case. If you get stains, discoloration, or light scratches on bug shields, use some "cleaner wax" such as 3M Pro Formula, it takes it right off and leaves a really nice shine.
  #37 (permalink)
Old 02-10-2005, 12:18 PM
Cyberbilly's Avatar
Moderator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 08:41 PM
Cyberbilly will become famous soon enough.
Send a message via Yahoo to Cyberbilly Cyberbilly's Photo Albums
if it was properly installed there are small strips of what looks like 3M tape between the "crimps" and the hood....the paint should not be damaged at all....an aside...i have a toyota bugshield which i really like...it stated very clearly on mine(mine had a big yellow sticker on it) that it should never be used in a carwash....
Kevin
I removed the Bugshield yesterday. That "3M" tape was a bear to remove. I had it heat it up with a hair drier to remove the tape, but most of the adhesive stayed on the paint. Lots of mineral spirits and elbow grease to remove the adhesive.
All a man really needs for happiness in this world is a good woman, a faithful dog, and a big-assed set of tires on his truck.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Audiovox ACA200W Rear-view camera, Audiovox XM Express Sattelite Radio Receiver, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Featured Sites: Truckblog.com Cardomain.com RateMyRide.com SportTruck.com TruckTrend.com
  #38 (permalink)
Old 02-11-2005, 08:28 AM
REDEYE6's Avatar
Dealer : Dan Cava's Toyota World
2003 Toyota Sequoia
Last Online: 12-29-2008 10:44 PM
REDEYE6 is on a distinguished road.
REDEYE6's Photo Albums
Default Googone
Cyberbill,
I had good luck using googone to remove the glue from my old rear spoiler on my runner, also try 3m adhesive remover (spray can) it also works well.
Regards,
REDEYE6
03' Sky Silver SR5 Sequoia
100K+ miles / K&N filter / (265\70\16 BFG AT KO / MagnaFlow /
more Mods to come
IQUE 3600 GPS/PDA Nav system
N39*25.88 W080*11.58
  #39 (permalink)
Old 03-11-2005, 08:04 PM
Last Online: 03-11-2005 08:04 PM
Okietundra is on a distinguished road.
Okietundra's Photo Albums
Default I need to replace my bug deflector
Originally Posted by heatmiser
Does anyone here have a bug deflector/hood shield installed on their Sequoia? I used to have a Ford Expedition with a really nice one that did not require any drilling and sat high off the hood so I could clean underneath it easily. This is what I am looking for with my Sequoia. Any recommendations?
I went to the Toyota parts center at my local dealership and they stated their deflector required drilling. This is not an option for me.
heat,
I just took off a broken bug deflector. I liked the way it looked on my 200 Tundra. And it didn't need any hole penetrations. Only two clips and tucking it into above the grate did the trick. I want to find one just like it. It was made in Australia, I think.
If any body knows how to find the bug deflector I described please email me.
Bookmarks
