This is a discussion thread titled "Spray in Bed Liner question.......", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-16-2005, 12:55 PM
TheGryme's Avatar
Dealer : Valley-Hi Toyota
2004 Toyota Tundra,
- Other - 1992 Toyota 4Runner
Last Online: Today 08:31 PM
TheGryme is on a distinguished road.
TheGryme's Photo Albums
Default Spray in Bed Liner question.......
I have owned my 04 DC since last Sept and have used it LOTS....trash every 2 weeks or so, clearing brush, hualing lumber for various projects around the ranch, desposing of dead bodies......the usual.
My bed is begining to look like cr@p.
Can a sprayed in bed liner cover us scratches and such or will they still show. Also.....how are the stock plastic bed caps dealt with on a sprayed in liner.....are they taken off and the mounting holes filled in with something?
TheGryme Ummmm Beer Good.....Whiskey Better!
'04 Tundra DC
Grey....V8 SR5 4X4 TRD Off Road Suspension, LSD, Towing Package, Nitto Terra Grapplers LT265 75 16's, Magnaflowed (w/ Secret AirBox Mods!), UNIChipped, True~Flowed, DeBadged, ScanGaged, XM'ed.....Yeah!
'92 4Runner
Black, V6, Downey / Rancho suspension F&R, 3 inch sus lift, 1 inch body lift, SAW T-Barz, 4:88's, ARB (rear), 32X12.50 BS Dualers on AR 8X15 Wheelz, Power Slots and Pads, Downey headers, MagnaFlo Muff, K&N FIPK, Ported heads, 1 piece stainless valves...way too much money in it!
'04 YZ250F
Dr.D Header and Can, JD Jetting, P38 AP, UNI Flame Proof Air Filter, No Back Fire Screen, Carbon Fiber Carb Heat Shield, Renthals, ASV Controls....
'87 Nissan Pathfinder......gave to son in Oregon
Old 05-16-2005, 01:16 PM
Last Online: 07-20-2005 07:16 AM
leechmcg is on a distinguished road.
leechmcg's Photo Albums
Default spray on
a spray on bedliner ($350.00) should cover the scratches, but if you would have got a bedliner sooner a drop in ($269.00-$300) would be have been the way to go
Old 05-16-2005, 03:34 PM
anmrivera's Avatar
Dealer : Performance Toyota Of Lavista
2003 Toyota Tundra,
2005 Toyota Sienna
Last Online: 10-29-2008 09:52 AM
anmrivera is on a distinguished road.
anmrivera's Photo Albums
Give Gone123 time to chime in on this one. I think the bedliner will help your appearance and protect the bed. If you use a drop in it will just hide it. I got under the rail so my bed toppers stayed put. gone123 can give you the specifics of how you can go over the rail and cover the holes. Good luck.
2003 Tundra 4x4 Access cab V-8, SR5, Silver Sky Metallic, TRD Off-Road package, Tow package, LSD, cold weather prep. package, Running boards, Convienence Package, Line-X bedliner, debadged, 4 window visors, Blue Cyber Eyes, $5 rs3200 upgrade , Fog light mod.
2005 Sienna LE 8 PAX, White, Full Curtain airbags, Tow prep package, VSC, Rear Disk brakes, rear audio, aftermarket entertainment center(will be bought soon)
I'm a proud Toyota Bigot!!!
Midwesterners checkout the midwest forum!Click here
Old 05-16-2005, 03:54 PM
TundrastruckDave's Avatar
Dealer : Greenville Toyota
Last Online: 01-03-2009 09:10 PM
I completely and totally agree with what (anmrivera) says! (123Gone) is WITHOUT DOUBT... the MOST KNOWLEDGEABLE guy on these boards about ANYTHING dealing with spray-in bedliners.
Not to mention... it'll also increase the "value" of your DC as well!
Mods to Date:
Mods to Come:
265/75/16 BFG A/T's,
Possible Mods:
Old 05-16-2005, 05:04 PM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: Today 03:32 PM
123Gone is on a distinguished road.
123Gone's Photo Albums
TheGryme:
I'm a LINE-X dealer. LINE-X is one of the major spray-in bedliner companies.
If you need to protect your truck's bed completely, you have three options:
1. Plastic drop in: The advantage is that they are inexpensive at about $150. Disadvantages can include one or more of the following:
Rattle/vibrate
Warp
Can't be repaired
No warranty
Trap water and debris
Rub the paint off the truck and can cause rust
Take up extra space in the bed
Generate static electricity
Does not conform to all contours
Can fly out of the truck bed
2. Bedrug: Bedrug is a good product, it's sort of like outdoor carpeting in your truck's bed. It's a nice alternative to drop-ins or spray-ins. They cost about $275 to $400. The only negative comments I have ever heard (and they are minor) are the following:
1. Only comes in gray.
2. Tends to sag a bit after a while.
3. Traps moisture between the rug and the bed.
4. You need to get used to looking at carpet in your bed.
3. Spray-in bedliners: Advantages are as follows.
Don't rattle or vibrate
Don't warp
Can be repaired
Creates a permanent water tight seal
Does not create rust
Allows for more cargo area
Does not generate static electricity
Dampens road noise
Molds to every contour
Will not fly out of the truck bed
Shopping for a spray-in can be difficult. Chemical composition of the product varies from company to company. Generally speaking, there are three types of spray-ins: 100% polyurethane (most common; Rhino, Toff), 100% polyurea (least common; Combat, Xtreme Liner), blend of polyurethane and polyurea (LINE-X, Viper). The three types exhibit different tear strengths, tensile strengths, temperature tolerance, abrasion resistance, etc. My personal opinion is that the bedliners that are a blend tend to be the better bedliners because both polyurea and polyurethane give the liner desireable properties. Discussion of the chemical composition can go a further. Such as there are one-part polyurethanes (also called "solvent based") and two-part polyurethanes. I'll stop here unless you want to hear more.
A spray-in will cover the scratches. The plasic rail caps have to stay on. Underneath each one, there are about 20 retangular holes that are too large for a spray-in bedliner.
You should decide which product gives YOU the best bang for the buck for YOUR intended use. Let me know if you have any questions. It can be a tough decision!
Old 06-01-2005, 03:53 PM
remelad's Avatar
Dealer : Lancaster Toyota
2005 Toyota Tacoma
Last Online: 04-02-2008 10:54 AM
remelad is on a distinguished road.
Send a message via AIM to remelad remelad's Photo Albums
123Gone covered a lot of good information here!!!
I spray liners by Spray On Products at my shop in Salunga, Pa. Spray On Products uses a hybrid Polyurea/Polyurethane chemical just as LineX & Viper, stated above. Like mentioned, it gives a great range of qualities over just one or the other.
My liners start at $375 unless we are running a special. As with LineX, they carry a lifetime warranty, are nonslip (unlike drop in's) and increase resale value of the vehicle. We usually do pretty good at filling dents and such and scratches are no problem.
I recommend spray in liners over drop in hands down. It would be a lot easier to sell drop in liners but I would prefer a customer who is happy with their liner for life.
Old 06-02-2005, 11:58 AM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: Today 05:53 PM
dsrtrcr01 will become famous soon enough.
dsrtrcr01's Photo Albums
Default You Could
I have seen a couple people asking about removing the caps when doing a spray in and I was wondering, Why couldn't you just weld some metal in the holes and when the spray in liner is sprayed it would cover the ugly welded in piece as well as the paint that got messed up by welding. Just make sure to grind down the welds and feather out the paint so there are no edges. I think this would look pretty good.
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 06-02-2005, 12:50 PM
123Gone's Avatar
2005 Toyota Tundra
Yes, that is possible. I even know of a LINE-X dealer that did that for a customer, but I did not actually see the end result. Your talking about welding about 40 holes. Very atypical, but it will work.
Old 06-02-2005, 01:05 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
A local shop sprays Arma. Is that the equal of Line-X? (We have no Line-X shop in my two county area.)
And, I know, the quality of the individual shop's prep work is very important.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 06-02-2005, 02:15 PM
123Gone's Avatar
2005 Toyota Tundra
I'm fairly sure (but not positive) that Arma uses a polyurethane/polyura blend product similiar to LINE-X. They do use a heat/high pressure system so it will look just like LINE-X. I don't know how the Arma will look after 6 months or so. There are no Arma dealers around here.
I'd say it's definately worth further investigation.
Bookmarks
Similar Threads for: Spray in Bed Liner question.......
'05 Tacoma bed--strange sighting MrDynamic Tacoma 8 02-15-2005 03:51 PM
Spray on Bed Liner Litlbul California 10 12-14-2004 05:31 PM
Bed Liner or Spray in ???? wHITEY Interior & Exterior 22 10-22-2002 03:05 PM
Bed Liner - Spray in or Underrail plastic? SMUAlien Interior & Exterior 21 09-11-2002 10:49 PM
Yet another bed liner question (line-x) fletch Interior & Exterior 15 04-25-2002 10:23 AM
