This is a discussion thread titled "Slide-In Campers?", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-12-2005, 08:19 PM
donstergarage's Avatar
Last Online: 12-30-2005 09:48 PM
donstergarage is on a distinguished road.
donstergarage's Photo Albums
Default Slide-In Campers?
Has anyone here used a slide-in truck camper in their Tundra, AC specifically? Most of them seem too heavy; 1400-1800 pounds empty. I found a lightweight one I like from www.six-pac.com but don't know if I can buy locally.
Don
http://home.comast.net/~donstergarage
2002 Tundra Limited 4wd TRD
Old 06-12-2005, 11:45 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
Last Online: 10-12-2008 11:01 AM
RockyMtnRay's Photo Albums
The question comes up every once in a long while but very few people actually have successfully used one for the very reason you identified...nearly all are simply way too heavy for a Tundra. An Access Cab has...at most...about 1200 lbs of load capacity in the bed if you have a passenger or two and a few hundred pounds of cargo in the cab. Since most people load a camper with 500 or so pounds of stuff, that realistically means the empty camper can't exceed 700 lbs or so. And that means that you have to go with the ultralight models from companies like six-pac or Four Wheel Campers.
Some people will tell you that you can overload a Tundra with no problems if you just install some overload springs or airbags to get the frame off the axle. They are wrong...unlike on domestic trucks where the suspension is often much weaker than the frame and axle; on a Tundra the frame, axle, and suspension are of equivalent strength. I have seen pictures of a Tundra with a cracked-all-the-way-through frame (on both sides of the truck) that resulted from hauling a 1500 lb camper that was loaded with about 1000 lbs of stuff. The idiotic owner of that truck thought his Tundra "could handle the load" if he just "beefed up" the suspension with overload springs. Instead he turned a $30,000 truck into a $3000 parts donor at a salvage yard. Another TS member reported his brother-in-law snapped the axle on a double cab at the spring mount by hauling a too-heavy load.
So if you're determined to haul a camper with your truck, buy the lightest one you can find (not to exceed 700 lbs empty), load it very lightly, don't try to increase rear suspension load ratings with airbags/overload springs, and stay on smooth roads to minimize shock loading on the frame/axle/suspension.
Ray
Old 06-15-2005, 07:41 PM
Looks like this thread got moved
Maybe, it's time to look at a used 3/4 ton diesel truck. I love the Tundra but a bigger truck w/ even better fuel mileage may be a worthwhile trade up.
Thanks Ray.
Don
Old 09-13-2006, 11:27 PM
SDtundra858's Avatar
Dealer : Toyota Scion of El Cajon
2004 Toyota Avalon XLS,
2007 Toyota Camry CE,
2008 Toyota Prius Package 2
Last Online: 09-17-2008 08:42 PM
SDtundra858 is on a distinguished road.
SDtundra858's Photo Albums
Default Re: Slide-In Campers?
I have a 2005 Regular Cab V8 2WD 8 foot bed, currently it has a 3 inch exhaust with Flowmaster Super 40 muffler and a K&N 77-series intake. The tires i have on there are 265/75/16 BFG All Terrains. I was wondering if the Ranger by Four Wheel Campers would be too heavy for my truck to carry Weighs only 780 Lbs unloaded and on their website they have 2 pictures of a Tundra Regular Cab with it on...Four Wheel Campers Ranger Model - Fits Mid/Mini Long Bed Trucks
Send me a PM with info, as i will probably forget about this post or not be able to find it again
Old 09-13-2006, 11:55 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
Last Online: Today 08:07 PM
mustang67408 will become famous soon enough. mustang67408 will become famous soon enough.
I don't know about the weight, Maybe RAy can address that, but
3" exh and that Intake set up, you've probably lost alot of LOW END torque. WE have found that increasing the exh size more than 1/8" has detrimental effects on low end torque. That is what you need to haul heavy loads.
This is just my opinion , not trying to bash you.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
Bookmarks
Similar Threads for: Slide-In Campers?
Toyota Tundra and Slide in Truck Campers dkocol Interior & Exterior 16 09-29-2008 01:49 PM
Campers for Tundra stevef Interior & Exterior 6 06-14-2006 03:21 PM
Slide In Camper Ripper Interior & Exterior 6 10-27-2003 10:48 AM
Truck Campers for Toyota Tacomas StanTheMan Interior & Exterior 2 01-26-2003 11:18 AM
Tundra and truck campers? mccleamf Interior & Exterior 5 09-06-2002 09:12 AM
