Newbie question of the day! (removing skidplate)
+ Reply to Thread
Results 1 to 7 of 7
Thread: Newbie question of the day! (removing skidplate)
  1. #1
    Lurking Member Hosehumper is on a distinguished road.
    Join Date
    Mar 2005
    Location
    virginia beach, va.
    Age
    44
    Posts
    22
    Liked
    0 times
    Rep Power
    9
    Default Newbie question of the day!
    I'm almost too embarassed to ask, but how do you remove the skidplate? All the bolts are removed from the plate and the plastic splashguards but the skidplate seems like it's hung up. I've tried to slide it forward and back but no luck. Gotta change that oil and filter. Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member healey858 is on a distinguished road.
    Join Date
    Apr 2004
    Location
    San Diego, CA
    Age
    33
    Posts
    113
    Liked
    0 times
    Rep Power
    10
    there are 2 hooks on the front of the skidplate. lay under the truck and push up and forward and the hooks should come out. hope this helps...
    ‘04 Tundra DC SR5 4X4 Silver Sky Metallic
    Factory Options: All-Weather Guard Package, V8 Towing Package, LSD, JBL Audio Upgrade
    My Mods: Donahoe Coilovers, Total Chaos UCAs, Bilstein 5100s in rear, Total Chaos Diff Drop Spacer, Total Chaos Steering Rack Bushings, Robby Gordon 17x8 Wheels, BFG 285/70/17s, JBA Headers (Ti coated), JBA Y-Pipe (ceramic coated), Magnaflow Muffler w/ 3.5” Tip, Volant Cold Air Intake, AudioVOX Alarm, Line-X, OBX Sport Pedals, Billet Antenna, White Guages, VSE Subwoofer, Clear Corners
    Future Mods: Tinted Windows, Billet Grille, UniChip, Glassworks Supercharger Hood, Sun Roof
  4. #3
    Veteran Member anmrivera will become famous soon enough. anmrivera will become famous soon enough. anmrivera will become famous soon enough. anmrivera will become famous soon enough. anmrivera will become famous soon enough. anmrivera will become famous soon enough. anmrivera will become famous soon enough. anmrivera's Avatar
    Join Date
    Aug 2002
    Location
    United Kingdom
    Age
    38
    Posts
    567
    Liked
    0 times
    Rep Power
    14
    Quote Originally Posted by Hosehumper
    On my 03 if I remember correctly I can safely remove all bolts and it gets hung up as well. What I do is dork around with the side that is closest to the rear of hte truck. Once you get that end lowered you have to angle it down and at the same time lift up on the front end. They are hung up on a "J" hook type of thin-a-mig-jig. Hope this helps, if not ask some more. "The only stupid question is the one not asked!"
    2003 Tundra 4x4 Access cab V-8, SR5, Silver Sky Metallic, TRD Off-Road package, Tow package, LSD, cold weather prep. package, Running boards, Convienence Package, Line-X bedliner, debadged, 4 window visors, Blue Cyber Eyes, $5 rs3200 upgrade , Fog light mod.
    2005 Sienna LE 8 PAX, White, Full Curtain airbags, Tow prep package, VSC, Rear Disk brakes, rear audio, aftermarket entertainment center(will be bought soon)
    I'm a proud Toyota Bigot!!!
    Midwesterners checkout the midwest forum!Click here
  5. #4
    Join Date
    Mar 2005
    Location
    virginia beach, va.
    Age
    44
    Posts
    22
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Got it off. Turns out all the bolts weren't off after all. Oops. Thanks for the replies.
  6. #5
    Veteran Member student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra has done just about everything...and then some. student's tundra's Avatar
    Join Date
    Mar 2005
    Location
    SOCAL, CA
    Posts
    1,166
    Liked
    4 times
    Rep Power
    929
    Glad you got it off. I briefly remember taking my skidplate off the first time. It was also the last time I would take that stupid skidplate off. Just weeks before I did my oil change I was out messing around in the dunes and plummeted into a small hill and folded my skidplate in half. Since I knew I needed a new skidplate and would have to remove the skidplate everytime I did a oil change (every 5000 miles). I decided to buy a skidrow engine skidplate. Best money I every spent. I payed about $50 more than the OEM skidplate and it is 3x thicker (3/8 steel compared to 1/8), looks better and allows me to remove the oil filter without removing the skidplate. Way cool!!!!!
    2003 2WD Tundra Imperial Jade TRD offroad
    2.5" Camburg C/O w/ 14" 600lb King springs
    285/75/16 BFG A/T and 16x8 KMC Black Enduro's
    4.30 R/P, Magnaflow 18", Superlift Tru-speed
    Pace Edwards Roll Top Cover, 06 Headlight conversion
    Got to have my toyz
  7. #6
    Junior Member docsg is on a distinguished road.
    Join Date
    Dec 2003
    Location
    Troy, AL
    Posts
    372
    Liked
    7 times
    Rep Power
    10
    Quote Originally Posted by student's tundra
    Where do you get a "skidrow" skidplate?
  8. #7
    Join Date
    Mar 2005
    Location
    SOCAL, CA
    Posts
    1,166
    Liked
    4 times
    Rep Power
    929
    Quote Originally Posted by docsg
    skidrow automotive
    aka www.skidplates.com
    Got to have my toyz
  1. Newbie question about keyless entry
    By Supraman93 in forum Electrical & Computer Systems
    Last Post: 11-12-2004, 02:55 PM
  2. Newbie Installation Question
    By sidepocket in forum Audio & Stereo
    Last Post: 10-11-2004, 04:01 PM
  3. Newbie with tire size question!!
    By franco802 in forum Tires and Wheels
    Last Post: 08-21-2004, 02:18 PM
  4. Newbie question ( backspacing )
    By James800 in forum Tires and Wheels
    Last Post: 02-23-2004, 01:45 PM
  5. O.K., here's my newbie question (exhaust & intake)
    By molex in forum Engine & Drivetrain
    Last Post: 12-13-2003, 06:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
