I've had the problem before in a Highlander. For some reason, if the wheels are turned to an extreme angle when the car is shut-off, it locks up the ignition switch, and makes it hard to remove or re-instert the key. Not sure if this is your problem, but see if the wheels are cranked over the next time it does that. The fix to this is always just to wiggle the steering wheel.
