Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 07-22-2005, 08:48 PM
2005 Toyota Tundra
Last Online: 03-12-2009 06:34 AM
Orbit may have some regrets.
Orbit's Photo Albums
Angry Hood protector installation on 2005 Tundra
I purchased a PT427-34032 Hood Protector for my newly purchased 2005 Tundra. Followed the installation instructions to the letter. While installing the "F" clips I noticed that they were not aligned with the hood. As I tightened the set screws onto the backing plate the "F" clips would slide down the hood. Once I closed the hood the "F" clips would fall off the hood. The angle of the "F" clips isn't correct. Has anyone ran into this problem?
Old 07-23-2005, 07:13 PM
Dealer : McGeorge Toyota
2004 Toyota Tundra
Last Online: 06-04-2008 07:56 PM
Xtrema may have some regrets.
Xtrema's Photo Albums
Yes. Suggest you return hood protector to dealer and get refund. Part ending in 030 requires even more @!#$%@#$% as you must drill the hood.
F clips would not stay on my hood. Bad design. And, when the hood is slammed shut the inertia of the hood deflector tries to keep the deflector moving, and the F clips will loosen.
Old 07-24-2005, 08:35 PM
Dealer : Heffner Lexus Toyota
2005 Toyota Tundra
Last Online: 06-28-2009 08:55 PM
4.7 vvt-i may have some regrets.
4.7 vvt-i's Photo Albums
Is this a Toyota hood protector? I'm thinking of buying one for my 05 since i've already got a number of stone chips, only had it for 8 months. I've seen a number of Tundras in the parking lot at work with the hood protector and they look good.??
Old 07-24-2005, 08:51 PM
2005 Toyota Tundra
Last Online: 01-09-2010 12:33 PM
Jonesie may have some regrets.
Send a message via AIM to Jonesie Jonesie's Photo Albums
I too would like to know if this is the Toyota/TRD part, because I was looking at one of these.
Thanks ~ David
2006 Tundra Double Cab SR5
TRD Off-Road with 4WD
Phantom Gray Pearl
Line-X Sprayed Bed and Drop-In Liner.
$25 OEM RS3200 Alarm System Upgrade
Old 07-25-2005, 10:33 AM
2005 Toyota Tundra
Thanks for the come back. I will take the part back to the dealer on my next day off. It is a Toyota supplied hood protector I bought from the selling dealer.
Old 07-25-2005, 10:37 AM
2005 Toyota Tundra
Yes it is a Toyota supplied Hood Protector. I understand there are two types that can be installed. I do not recommend this one due to the fact that it is not fastened to the hood with screws/bolts but only by pinching the hood. Once the light weight scuff material that is supplied with the Hood Protector wears off, I can see that it would then be rubbing the paint and you would be looking at a new paint job for the hood.
Old 02-06-2007, 08:50 AM
Dealer : Courtesy Toyota Scion of Orlando
2006 Toyota Tundra,
2005 Toyota Highlander LIMITED-BLUE
derryg may have some regrets.
derryg's Photo Albums
Thumbs up Hello
Hi Everyone,
Just bought a 2006 Tundra enjoying it. I bought a subscription as I find these forums more informative than talking to a service advisor. It's always better to be armed with prior knowledge when a problem occurs than numerous trips to the dealer.
I look forward to the vast knowledge of members and the forum. I'm currently viewing information on OEM Hood Protector installation.
Old 02-06-2007, 02:26 PM
larycut's Avatar
Dealer : Toyota of Riverside
2004 Toyota Tundra
Last Online: 02-20-2010 10:28 PM
larycut may have some regrets.
larycut's Photo Albums
Default Re: Hood protector installation on 2005 Tundra
I have a Ventshade been on 1 year no problems, easy to install you have to install self tapping screws on the underside of the hood on each end the screws are short and very easy to install.
Larry
2004 Tundra AC Limited
Added to date Bilstein 6024, 6025, FMS Sports Grille. De-Badged, Kenwood KSC-SW1 Subwoofer in storage compartment rear passenger side, Infinity 6012i & 6012si 6”sub in doors, Kenwood DNX 7100 w/XM, Turboliner bedliner, J & J Chrome Running Boards, chromed factory rims, K&N cold air intake, Window tinting. Viper Alarm and Viper GPS systems, Personal Identity security system,SilverStar 9003st headlight, 05 tail light, clear corner lens with 3157ast Silverstar, DynoMax exhaust
,Muth Signal Mirrors, SnugTop Snuglid SL hard tonneau.
Old 02-22-2007, 11:19 AM
Cali D's Avatar
Dealer : Bingham Toyota Scion
2002 Toyota Tundra
Last Online: 02-27-2009 12:20 AM
Cali D may have some regrets.
Cali D's Photo Albums
Before you go drilling holes in your hood, you might want to check out this invisible mask by 3M.
::Invisible Bra 3M ScotchGard Paint Protection for your car
2002 Limited 4WD TRD access cab
Rockford Fosgate front&rear K&N FIPK2 Series 57
Extreme Flow 3" cat-back 4"D 14"L rolled slant chrome tip
N.R.A. hitch plug Aftermarket lighting
Some people live an entire lifetime and wonder if they have ever made a difference in the world, but the Marines don’t have that problem.
—President Ronald Reagan
2005 Tundra Taillights BOLTHOUND Electrical & Computer Systems 3 10-20-2006 01:58 PM
2005 Tundra Double Cab nerf bars won't fit faaengr Interior & Exterior 7 09-28-2006 06:37 PM
2005 Tundra SR5 Db Cab Running Boards??? Hubert McCoy Jr Interior & Exterior 7 02-04-2005 12:05 PM
Tundra Lightweight Fiberglass Hood Finntastic Interior & Exterior 9 12-05-2003 11:37 AM
